Did Pads and Rotors on a TT
Have a 11' Turbo and I finished my brake job last weekend and saved over $1000 by doing it myself. I used Textar pads all round, OEM front and Meyle rear rotors. I reused my wear sensors, pad clips and bolts. I know your "supposed" to replace all of those parts but I have never had an issue. Flushed the brake fluid and bled with an amazon pressure bleeder. The pedal feel is as good as it was before so I am happy with the results.
For those that attempt this, get the front caliper tool (many other posts confirm this) to hold the calipers while you change things. Well worth the $40 and headache if you don't have them as the calipers are heavy. Take the brackets off the hose lines first before you take off the caliper. Remember when you do the rears, put it in neutral and leave parking brake off. If you have air suspension, don't forget to put it in service mode (push up on the adjustment leaver for 10s, to restore when done, do the same thing).
I hope this helps someone in the future and if you have done a brake job before, it's not much different, just HUGE calipers.
Originally Posted by Ghost Ryder
Where did you buy the parts? Do you know of any aftermarket front rotors? Where did you by the caliper tool?
I got the tool from http://www.baumtools.com
Most of the parts I got from PelicanParts. There is one aftermarket supplier for the front rotors but they were the same price as OEM ones from sunset porsche parts.
A couple additional things as I remember.
I put out the front on jack stands so I could easily turn the wheels to get access to the top bolt that hold the bracket for the brakes lines.
Need to remove the wheel speed sensor clip to get more slack in the lines when you pull off the caliper.
Front caliper bolts were a star socket while while the rears were an xyz torx.
I put brake assembly fluid fluid on the back of the pads and no squeeking.
i was able to press the pads down to compress the caliper pistons mostly by hand and also used a pipe clamp (no pad spreader required).
Front caliper bolt torque was 104 ft lbs while rears was 64 I think.
if your flushing the brake fluid and general bleeding should be done passenger rear, drivers rear, passenger front and driver front last.
Also helps with access for one clip for the break line as geometry of the suspension changes.
Also, if you are doing your brakes, spend the cash on the hardware. The caliper bolts are one time use hardware. They can be reused but they are cheap. The new clips will help with irregular brake wear and squeaking.
