Spare tire tools
Good point TxHoon. I do have that actually but, I took the locking lug off due to my new rim setup.
Just seems like Porsche has a lot of empty areas. I have a empty area in the lift gate which is supposed to contain a safety triangle. I think that may possible be Europe spec.
Ok, I went a looked at my (new to me ) '16 GTS. There is a different set up on this one compared to my '14 Diesel.
The lug wrench is stored under the jack on the left side of the '16. The large open space on the top tray (2nd picture) had a clear container that had rubber gloves in it on my Diesel. It is also empty on my GTS. You should have another screw driver insert below the black handle screwdriver in the second picture also.
I did not see or notice the threaded pin in my kit so I will have to look again.
I also keep a bottle of slime and associated tools, a safety vest and a couple of sets of gloves in my tire well. I put a first aid kit in the small hatch on the passenger side of the cargo area.
I had to change a tire on my 2016 S and there was no tool to loosed the nut holding the spare down tightly Called AAA, truck shows up with no tools on it Had the car towed home, did a tire change and put all the missing tools back there with a large towel. Maybe do a practice run?
