Jerky Shifting into 3rd and 4th Gear in my 2012 Cayenne S
#31
You must be retired, lotsa time on your hands?
A 3-4/4-3 shift issue has ZERO to do with boost.....
Original Post Topic = "Jerky Shifting into 3rd and 4th Gear in my 2012 Cayenne S"
BTW - My '11 CTT - never felt particularly rough to me - but it wasn't silky smooth. I just put this down to the nature of the beast. It also never showed much boost (which it turns out is apparently another symptom of a slipping transfer-case clutch.)
First real long high-speed drive tonight of it since I changed the fluid. As much as it changed the around-town feel of it - the change on the highway is amazing. It is SO smooth now. And boost starts up as soon as I start putting my foot into it, and unlike before - the boost holds as long as I keep my foot into it.
It never felt awful before. It feels WONDERFUL now. I'll be doing a second change in another 500 miles or so - just to make sure I got ALL the old burned fluid out. And my suggestion to everyone with a gasoline powered 958 - make this part of the regular maintenance schedule. I plan on doing it every other oil change. It will add 5 minutes to an oil change. Well worth doing.
#32
Received 1,140 Likes
I didn't say boost had anything to do with the rough shifting. But boost can be retarded apparently by a slipping transfer-case clutch that results in rough shifts. The rough shift triggers the retarding of boost.
My point was - my boost was never very impressive. Now that the transfer case is working smoothly - it is. And for someone having rough shifts - before assuming it's the transmission - there is a lot more to a driveline than just the transmission (which appear to be trouble free on the 958 series.)
Have a nice day.
#33
I just purchased a 2012 CS that is under CPO for another month. I felt the jerky shifting, called the local dealership, explained the issue over the phone and the SM was quick to say the problem is the TC. After I left the car for several days, they called me to say they couldn't find any issues. I clearly have the TC problem, but the dealership doesn't want to seem to help. They said, if there is a problem, it will have to get worse before they fix it... What should I do?
#34
And get your complaint and their response documented fully, in writing (or print).. so when it does go really bad you have something to wave at Porsche Cars North America (assuming you're in NA..)
#35
Don't wait. This was exactly what my dealer said and now my warranty is over and the problem gotten worse. And Porsche north america can give less of a f#ck about me and my problem.
#36
I should have posted follow up months ago. Dealer replaced my TC under warranty and it made a big improvement on my 3-4 and 4-3 shifts. They still are not as smooth as all other shifts but now barely perceptible.
#37
My 2013 Cayenne GTS is having the same problem (80k miles). I'm going to take it in and first have the transfer case fluid changed. I'll report back if that is a fix.
#38
Well, the fix for my 2013 Cayenne GTS was a new transfer case. Unfortunately, I was out of warranty. It seems to have fixed the issue, but was about $5,700. I previously made a conscious decision not to buy the extended warranty and to self-insure. Perhaps the warranty would have been a better way to go. Time will tell.
#39
Should have added that the Service Advisor said they have seen the transfer case issue quite a bit. The fact that they had a new transfer case in stock may say something...
#40
#41
I did talk with the Service Advisor about fluid change as a possible fix when I dropped it off. They called after driving the car and said it was the TC, and when I again asked if a fluid change would fix it, I was told that it would not. Wondering if I should have pushed for the fluid change. Have a number of these cases been rectified by a fluid change?
#42
Think about the dealerships motivation. Hmmm.... $50/fluid, 1/2 hour work max VS new transfer case & install - $5k? When you talk to a "Service Advisor" remember that their job is to sell service. They undoubtedly are rated by the $$ amount of service that they sell every month.
And if it doesn't work - hey - you tried (and can use that story with SWMBO when she complains about the expense on that damn car again..) Sorry to see you asked after spending the $5,400 - but perhaps it will serve as a lesson to others. (Someone once said "My role in life is to be a bad example for others.." - I sometimes feel this way..)
#43
Only about 90% have either been cured or shown improvement with a fluid change. And it's very easy and cheap to do. Go look at our Cayenne DIY forum. Print out the DIY. Take the car to a good independent with the Pensotin oil spec'd in the DIY - and have him change it. Easy.
Hope this helps.
#44
I think you will need to sit down once you hear the transmission fluid and filter costs. I will, as others will, be interested to see if the SA advocates this. I was talked out of a tranny fluid change by 2 dealers on my now 80K 2102 S. Still don't know which way to proceed. I do plan on keeping my PiG well into its golden years. All other fluids have been changed proactively.
#45
I hear ya, I know it's gonna be a doozy. 'A few hundred in labor and fluids' is quite the understatement. I have a private moonlight shop that specializes in Porsche Service near me so it's considerably less than a stealership, but I'm prepared for the worst and hoping for the best as they say. I don't have any jerky shifts at the moment (These Pigs were never the smoothest shifting things on the road), but I figure that if it's suggested at a certain point, I don't want to wait until its clunkin' and jerkin' before I do it. As previously stated, I've been amazed how much a fluid swap can change a car. Previous manual cars of mine were night and day differences after swapping the Tranny fluid; shifts like butter. I'm petrified of anything breaking on this car ($$$) so I figure an ounce of prevention could go a long way. Similar to you, I plan on keeping this car for a long time. I'll try and rely what he says.
Cheers
Cheers
