Milltek for 958
Milltek for 958
During my last track day, the stock muffler apparently broke a baffle so I needed to replace it with something quiet (my preference). After looking around and not finding a whole lot of useful videos on YouTube and some of the forums I went ahead and chose the Milltek SSXPO109 that is resonated and uses the stock exhaust tips. I ordered it through ECS Tuning in early July and it got here this past week. There were none in the country according to several vendors so I had to wait for it to get here.
The packaging wasn't that great and as a result there are scratches and very minor dents on several pieces. I don't believe this is ECS' fault as this was probably how it was packaged at Milltek. Basically they took the foam bags and put those in the box, put the pieces on top of that, then added more bags of the expanding foam to that. It might have held together better other than the large box it came in was already bent and some of the flaps on the bottom were almost torn through the tape to seal it. None of the polished pieces were wrapped in plastic either. So if you are all about aesthetics, this might not be the exhaust for you. You can judge for yourself about the welds, I am just guessing but it appears that the muffler cases were shortened to fit the application. Welds on the piping look pretty good but the smaller (more difficult) welds aren't the prettiest.
The system did come with all the bolts for the brackets and clamps to put it on. None of the tube ends are bent so it should go together easily. Brackets look sturdy.
I'll post follow-up after I get it installed today. I think mosquitos will be the biggest problem (it's been raining here for days). Here are some pics before installation on some of the components.
OK all installed. It took me about 3.5 hours with just me doing the work and the suspension set (and locked out) at the highest level. I did use a couple of jack stands just in case, though. The time also includes a test drive so now I'm waiting for it to cool down to check all the connections. Install was pretty straight forward. The most coaxing with a rubber mallet was getting the secondary cat delete ends to match up with the resonator pipes without pulling the h-pipe apart in the process. My one dented/scratched muffler is on the passenger side and unfortunately it is on the bottom, facing the rear. If I were to take a pic from the ground you could see the damage. I'm not worried about it and will send a pic to ECS to see if they do anything or not. Everything sealed up nicely so no leaks.
Sound is much deeper at idle and low rpm. Once underway it is barely noticeable and with the radio on I don't hear it any more than the stock exhaust. It does have a nicer rumble, though. Full throttle doesn't seem any louder. So for me, this has met my expectations of being on the quiet end. Most importantly, no more rattle!
A few more pics to share. I do have the PDCC hydraulic rear sway bar and it clears it fine. Pics are at the highest level on the air suspension. And don't let the badge in the rear fool you, it is a turbo. The original owner had it de-badged.
My 958 turbo broke a baffle at Palmer Motorsports this Sept. It seems the suitcase muffler doesn’t like the track. Do you have a video with sound of the milltek at cold start? Thank you.
I upgraded to these because they're 2.76" and I wanted more power (Turbo E81 intake & throttle body, 2.5" fabspeed exhaust/HHR bypasses, and tune). SO, I have fabspeed exhaust and HHR pipes sitting in the garage if you or anyone else is interested!
