Sport Plus option
Sport Plus option
Has anyone installed the Sport Plus Mode for the Cayenne? Suncoast sells the following part: https://www.suncoastparts.com/produc...SPORTMODE.html
I'm curious if anyone has any experience with this.
From what I understand it replaces the whole button panel (the one just in front of the cupholders). Then it requires a trip to the dealer to have them use PIWIS to enter an activation code (that's tied to your VIN) to allow the vehicle to recognize the button panel and enable Sport+.
^^This^^
Cheers,
TomF
Im really interested if anyone has experience in what the resulting changes are when activating this option. Any increase in performance, acceleration, throttle response, etc.?
If at all possible, see if you can find your same year/model Cayenne on a dealer’s used lot with the Sport Chrono option, and take a test drive. The software installed with the OEM sport plus kit will provide the exact same engine/tranny/suspension performance enhancements to your vehicle.
I have sport+ on my cayenne s with air/pasm. Have used it less than 5times in 20k miles. A novelty more than super useful imho. Cool that it lowers with air suspension. I don’t notice much difference in throttle response or tranny.
I know it makes a big difference on my 2016 turbo. The throttle response and the gearing is night and day from the regular or sport mode. With PSE on and the Sport+ on, the car sounds and performs like a Porsche..
Yeah, clear as mud, kinda.
Sport mode made a significant difference on my previous CTTs and now on my Macan GTS, and Sport Plus mode which my Macan GTS also has is significantly different in terms of throttle response and transmission behavior versus even Sport mode (not to mention ‘Normal’ mode). Then there’s also the changes to the suspension and steering setup in Sport Plus (my vehicle has Power Steering Plus). In fact the Sport Plus mode is significantly different enough that it’s really not suited to street driving in my experience, definitely more of a track mode. Plus it gives you a legitimate launch control feature.
Really? Based on my experience in various Porsches I’ve had using both Sport and Sport Plus modes, I’m surprised by your lukewarm assessment.
Received 1,140 Likes
Originally Posted by CarGuyNVA
my previous CTTs
BTW - sport mode on my CTT is noticeable. The shift points move up in RPMs and the throttle response changes to be sharper. More rev's in general. On the Macan/S that I had for a loaner it was even more noticeable. The Macan felt slightly crazy (in a nice way) in Sport mode.
Sport+ just feels like a novelty to me (personally). It lowers my air suspension and puts PASM in Sport+, opens the exhausts, etc. I think it reduces the fake fart on upshift (which is nice), and massages shift and throttle points as well. But, IMHO it's a bit too aggressive for street/daily and I rarely canyon carve in the Cayenne. I think there's a much larger delta from base->sport than sport->sport+. I'd be perfectly happy without it, but do occasionally trigger it just to play.
I think you missed:
CTT = Cayenne Twin Turbo.. his previous car was a Cayenne turbo - which undoubtedly came with the 8-speed Asian box like they all do (ain't no ZF's in Cayennes..)
I like the Sport+ (Sport Chrono option) as well, but I still get a lot out of the PSE regardless of using Sport+, Sport, or just activating the PSE button on the console in standard mode. At least that’s the case on the Macan GTS. I do notice however that the tone of the PSE does change a bit between the modes, getting progressively deeper and more volume as you move up through Sport and then Sport+. You can hear the difference even idling as you cycle through the modes. I’m not certain if it’s the same with the Cayenne system?
