Any issues with 22” wheels on a Cayenne GTS? What tire size to go with?
i was wondering if there are any issues with throwing a set of 22” concave wheels on a 2016 GTS?
will the dash display still be able to read the tire pressure? Also, what tire size would you recommend for 22 x 10.5?
Former Vendor
Just make sure you get a wheel with a load rating that meets or exceeds the vehicle specs. Otherwise you will end up with bent and or cracked wheels. Tire sizing would be 285/35/22 as stated by MJG911. TPMS should pick up just fine.
