Transmission Control Unit - Rennlist - Porsche Discussion Forums
Cayenne 958 - 2011 --> For newer Cayennes than the 955/957 series
Sponsored By:
Sponsored By:
Old 03-13-2018, 03:57 PM
Newegg
User
Newegg's Avatar
Default Transmission Control Unit
Post tune shifting on the Cayenne has not received rave reviews. There was a guy on one of the touareg forums that put a new Transmission Control Unit (TCU) in his rig, had the new tune done, then put the original TCU back in and was able to preserve the original shifting. Does anyone know where this TCU is located? A new TCU is about 650 bucks and I am sure it needs to be coded to the car by the dealership.
​​​​​​https://www.pelicanparts.com/More_Info2/95861812040.htm
Newegg is offline
Old 03-13-2018, 04:16 PM
deilenberger
Moderator
The TCU is located under the front passenger's seat. It isn't clear to me what you're attempting to achieve here. Do you mean that the TCU programming is changed by the "tune"? Shift points changed? Can you refer me to a link outlining what the complaint actually is? (Post tune shifting)?
One thought that comes to me - if the tune changes the HP/torque curves enough the old shift points may not be optimal. There is a simple fix for that - reset the transmission adaptations and let it learn where it should shift with the new torque/HP provided by the new tune. It would eventually learn that anyway since it is adaptive - but you can hurry it's learning curve along by doing an adaptation reset (doable with an iCarScan, dunno on Durametric - but probably, and I'm certain PIWIS does ie.)
deilenberger is offline
Old 03-13-2018, 08:11 PM
Newegg
User
Newegg's Avatar
Thanks for the info on the location. Yes I am referring to the way the car shifts after the emissions fix. There is a very long thread on this in the emission fix thread.
You do make a good point about the engine tune and the tranny tune being matched. Certainly could screw things up if I installed the old tcu with the old mapping/tune settings.
May have to set the whole idea to the side for a while and see how this all plays out.
Newegg is offline
Old 03-14-2018, 10:02 AM
Eskimo1
Eskimo1's Avatar
One Touareg guy bought a used TCU and installed it prior to bringing his car in for the fix, and then swapped it back out post-fix, and said nothing about having to change a thing (programming, etc.) while swapping, and has even offered to loan out the used one for folks getting their fix performed. Wish I had thought of that!
There is talk of JRAuto (the Canadian Tuner) being able to do transmission tuning soon (was only posted a week ago), but several noted that Aisin transmission tuning has been attempted many times before with no success at cracking their encryption.
Eskimo1 is offline
Old 03-14-2018, 02:05 PM
deilenberger
Moderator
It's still not really clear to me what this swap "avoids" or prevents. If there is an issue with adaptation - just reset it and let the system learn it over again.
As far as an Aisin transmission - the 958 doesn't use one. It's an 8 speed ZF (German).. perhaps the Touareg is an older model?
Old 03-14-2018, 02:21 PM
Eskimo1
Eskimo1's Avatar
The transmission programming was changed as part of the emissions fix. It's the hard-coded "mapping" that controls the shifting behavior, not adaptation.
The diesel does not use a ZF trans. It uses an Aisin TR-80SD, same as the Q7/Touareg.
Eskimo1 is offline
Old 03-14-2018, 03:01 PM
chsu74
chsu74's Avatar
This I have noticed. Wonder how much an ECU tune can overcome this?
chsu74 is online now
Old 03-14-2018, 04:02 PM
deilenberger
Moderator
That's the very first mention of diesel in this thread. Shows why listing the year/model of the car being discussed in either the thread title, or the first posting, or the poster's sig, or all of these - is a damn good idea.
Old 03-14-2018, 04:25 PM
Eskimo1
Eskimo1's Avatar
True - always good to specify, but when Touareg is mentioned along with "emissions fix", pretty safe to assume he's talking about the diesel.
Eskimo1 is offline
Old 03-14-2018, 10:33 PM
deilenberger
Moderator
This is what I replied to:
While Touareg is mentioned - "tune" is mentioned but nothing about emissions fix.. so..
Old 03-14-2018, 11:27 PM
Newegg
User
Newegg's Avatar
Sorry for the confusion guys. Appreciate the help. Will be sure to list car specific in the future.
2015 Cayenne Diesel.
Newegg is offline
Quick Reply: Transmission Control Unit
Contact Us Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
