Glove box LED bulb
Glove box LED bulb
I've tried different brands of LED bulbs with CANBUS free error for the glove box on my 2013 Turbo and nothing works. The first LED did not light up at all (yes I did 180 degree flip). The second LED (different brand/type) with 8 SMD got fried as soon as I plugged it in. For the first 1 second all 8 SMD lit up and then 7 went out with 1 LED still on. Same result with a different LED bulb.
I use the same LED bulbs for the footwell and door lights and they all work fine. I've searched the net and this forum but found nothing. Is there a special LED bulb for the glove box? Should I try the LED without CANBUS?
The whole 'canbus' scheme often is just a resistor stuck in the circuit to fake out the detection. This by raising the wattage consumed, and as a side effect making a lot of heat. It's typically safer to replace the whole light assembly with an LED circuit. There's a lot of them shared across multiple vehicle brands (vw/audi/seat/skoda). The key is finding the part number on the existing light and cross-referencing that via online searches. Mine already have LED so I didn't have to do this.
Most LED setups for internal lighting are 'all in one' where there's an LED element on a circuit board that clips into a clear plastic lens. That's what I believe is in my '17 GTS. If I'm not mistaken, the glovebox uses a similar assembly to that down under the seats and dash, illuminating the 'footwell' area.
When you're new, the Search feature is your friend.... hint.. hint... I say this because we all depend on each other to contribute here...
I believe I posted pix of the internal items, either here or on 6speed.
Yep, advanced search is super-helpful when trying to find stuff... Search on my username and 'footwell' and you'll find a few posts that might help.
What you can do is pop one of yours loose and see if there's a part number on it. That and does it look the same as the pictures I posted?
If so, search the web for that part number and see what it cross-references against. Eventually there's going to be another audi/vw/seat/skoda that likely used the same part, or has an equivalent. Once you know what other models have used that part you can then use that on aftermarket replacement websites to find a suitable LED replacement. Follow me? That was the path I followed figuring out my door lights. That's also how I figured out the warning reflector triangle in the rear hatch.
I do not. As I mentioned, mine are already LEDs so I never needed to figure that out.
Any chance you could post the measurements of the black box behind the lense? Just want to make sure it’s the same as mine before I order the whole set. Thanks in advance.
Update on interior LED lights
I took wkearney99 advice and purchased a set of 5 OEM LED housings on eBay using part number 5G0947409. Install is very simple, just swap them with the LED ones. It costs me $30 for the whole set. Porsche wants $33 for just one housing and it’s not LED. Thank you wkearney99.
Excellent news. Sorry I haven't been able to follow up on pulling mine apart again. I tried getting it loose and it wouldn't budge. I didn't have the plastic spudger tools handy and hobbling back/forth to the shop wasn't on my list of approved activities. Glad to know you found a solution! Take and post some pix of the results maybe?
They’re identical to yours based on the pictures you posted a while back, made by VW for Cayenne, Skoda, Touran, Tiguan, Passat, etc. Best is I didn’t have to pay Porsche taxes.
I was unable to take the glove box light at all. I did doors, footwells (the rears were also a pita to remove) and the trunk, but I was not so lucky with the glove box one.
BTW - I had problems with making the LEDs work as well. As it turned out, all that was needed was gently squeezing the metal tabs holding the bulb for proper electric contact.
