$550 for cayenne battery
looks like my 2014 cayenne turbo s will need a new battery. i had a "battery protection was active while parked " message in my display so i took it to dealer , they checked it out and "verified battery not fully charged " . battery "tested good ". they charged it and turned it back to me with a recommendation to replace battery . a day later the battery was dead. i was quoted $550 for a new battery plus installation which involves "coding" total cost around $750 for the dealer to do the job. wonder if any others have had similar experience ? am trying to get this done under warranty (my warranty started march 2015 - i purchased new october of 2015) but it look like i may have to cover it myself. i believe battery should last longer than 2 + years. the service record shows that dealer installed a new battery in 2014 sometime before i got it. thanks for any inputs. dan
Going through same thing with my 14 GTS - I'm at 50,700 miles and the battery is only warranted to 50k miles, even though I am CPO. Dealer wants $900k for battery plus install - GTFO. My trusty indy is getting the exact same battery from his Porsche contact and installing it for around $600, which I still find outrageous but better than $900.
You should absolutely be covered for replacement as long as you drive 6k miles a year and are under 50k miles. I confirmed this with 2 local dealers today when I was trying to get mine covered.
So much for Porsche goodwill - my battery is 3 1/2 years old and just barely past the 50k mark.
desmotesa, that is what i am tempted to do except for the fact that the battery is the largest part of the cost (i haven't priced out a battery from non porsche source yet ) also told there is coding involved with the install .
If you do more research you'll find that there's really no coding involved. Yes, it's shown on the PIWIS but, as I recall, it doesn't change any settings.
Check out post #8
https://rennlist.com/forums/cayenne-...questions.html
Check out post #8
change battery yourself.. Porsche doesnt make batteries, they source them. I dont like being taken for a ride, and dealer selling a battery with porsche sticker on it for 2-3 times the street price would offend me deeply.
I would buy the best battery you can buy, one that meets or exceeds all factory specs and have the dealer "code" the car when you are at the dealer for a visit in future.
Unless someone can correct me, I think there is no coding involved, or at least none that will change any settings.
The Cayenne workshop manual states that the battery part and serial numbers as well as manufacturer and capacity must be registered in the Gateway on-board unit using PIWIS.
I guess this is to ensure correct charging, and I am sure it is to ensure that customers use a Porsche workshop to do this.
Cheers, Tore
Cheers, Tore
Received 1,140 Likes
Cheers, Tore
Cheers, Tore
I wouldn't worry about it. When I replaced mine about 2 years ago, I called 2 dealers to ask about coding the battery. Ended up talking to the shop foreman at one dealer and the service manager at the other. The response from them was uniform: "Huh?" "We've never done this.."
YMMV - now about 30,000 miles on the "new" battery (from Batteries Plus+) seems to be working just fine.
Cheers, Tore
Cheers, Tore
The other thing Porsche does - is control charging rate to maximize MPG, which lessens the gas-guzzler penalty they pay. In normal mode, charging voltage is typically around 13.7V. Press the Sport mode button - and watch the voltage jump 1V to 14.7V. Why? Because MPG is measured in "normal" mode.
Sport mode on or off, on both vehicles, 14.7 volts.
