PPI report interpretation request
Long time lurker here, but first possible porsche purchase. The ppi kind of scares me. I want a 2011+ turbo loaded with most goodies and this one checks most of the boxes. I'm handy, but not a porsche mechanic. Can you decipher the report and codes for me? Leaking tcase due to overheating fluid and it getting slung out or do the seals leak at all?
thanks!
Im more curious about the other codes since I dont know what exact issues they indicate.
Code 602 is one that typically indicates the battery is at fault.
A faulty charging system could also flag this code but considering the year and mileage its more likely a faulty battery.
In fact all of the remaining codes could be caused by low battery voltage.
The Cayenne is known to store numerous unrelated error codes if the idle voltage drops below 13.5V.
A faulty charging system could also flag this code but a 2011 with 54K mi. not as likely as a faulty battery.
The Cayenne with all its modules can store numerous unrelated error codes if the idle voltage drops below 13.5V.
Received 1,140 Likes
Moving this to the 958 subforum.
That many codes to me means the PPI should be done at a dealership where they can give an estimate to repair. You'll pay more for it - but if it prevents you from buying a dog it's paid for itself many times over.
BTW - the transfer cases aren't known to leak. That isn't a common fault. And being a 2011 CTT it certainly is subject to the recall for the Variocam adjusters - or they may have been done preventively (don't count on it though - check - through the oil filler hole - it only takes a minute and a $3 dental mirror) - if they haven't been done, there is the possibility of failure before Porsche finally gets off their butt and has parts to do the recall. The failure can be simply the engine stops, up to the engine self-destructs. Not a real problem since Porsche is on the hook for it anyway, but it could be an inconvenience. The stickies are your friend - read them and then come back to ask unanswered questions.
Is there another page to this report? If not, it seems pretty half-***. I'd want all plugs pulled and examined along with a compression test on any vehicle. When it comes to a Cayenne, I'd also insist on a borescope inspection of every cylinder and a leak down test.
And why did they ding him with a $4 hazmat charge?
Labor rates are probably close to $150/hr, so this was probably more like a once-over with an ODB scan. I'm guessing the potential buyer opted for this instead of a full PPI.
The dealershop that did the ppi is chicagowhiz or something like that. It wasnt me that ordered it. I saw their name on the carfax and called. I asked my local dealership on the way home tonight after work and they wouldn't help. Zimbrick European (porsche and others) in madison, wisconsin.
