2011 CTT Launch Vehicle
Any reason to stay away or be concerned with a launch vehicle over a new 958? I'm currently looking at a CTT Launch vehicle. Do the Launch vehicles include anything extra? Surprised to find out it wasn't part of the camshaft bolt recall. Were some 2011's excluded? I'd think the bolts used were the same from 2011 - 2012. Thanks guys!
I think the turbos were excluded, but I could be wrong. I'm also looking at a 2011 CTT. What's the rough price range you're seeing for yours?
I'm looking in the mid-30s for a 80K mile, great condition, stupidly-loaded one.
Received 1,140 Likes
Turbos are for sure INCLUDED. Mid-30's is a bargain. Great cars once the few flaws are addressed. The launch vehicle should certainly be included in the recall VIN range. They started with the aluminum bolts in 2010 engine assembly.
Now that I've gone way off-topic, as far as I know any 2011 and some 2012 V8 (N/A or TT) is part of the recall.
Yup, Delly is right - checked the recall notice right after and forgot to edit my post.
This car has a build date of 4/2010 which is why it isn't part of the campaign. Just called Porsche to confirm. I guess the Launch vehicles didn't use the bad bolts....
Before purchasing the vehicle I'd spend the 2-3 minutes it takes to check them. How is detailed in the thread on the Variocam failures.
I supposed it's possible some of the early 958 vehicles used leftover engines from the end of the 957 production run. There isn't much difference in the engines that I've seen - but that would be the first time I've heard of this. Sounds to me like the mythical 955 V8 that got aluminum pipes from the factory - which simply didn't ever happen.
Can you kindly define what you mean by "Launch" - I'm assuming that's cars that were available when the model was first released to the public? What sort of time frame from first release until ??? does "Launch" consist of?
“Launch Vehicle” is actually list as an option. I think dealers are offered launched vehicles when a new model is launched which have a fixed set of options chosen by Porsche.
I will check. Didn’t realize it was that easy. But my VIN is def not included in the recall.
FWIW - on Facebook's Cayenne group - someone was on a test ride with a 2011 S and within a mile of the dealership the bolts broke and seized the engine. It does happen..
Ah - that's 'cause it wasn't in that thread. It's in one that's disappeared off the page I suspect, and in another sticky "IF YOU'RE THINKING OF BUYING.." as posting:
https://rennlist.com/forums/cayenne-...l#post14119956
Easy-peasy. Dental mirrors can be found in any large chain drugstore for a few bucks.
There are TWO Variocam units on the V8 engines - one for each cylinder bank. If only one Variocam unit was replaced - then the other one is a ticking time bomb.
Are there service records for this vehicle? Without those, and you looking under the oil cap - it's all guesswork. Even looking under the cap may be guesswork if only one Variocam adjuster was replaced. If there are records - a scan or photo of them would give part numbers and we could determine what was actually done.
The bolts that are bad are an integral part of the Variocam adjuster - if the adjuster is replaced - the new bolts are in the new device already. If there was a very early failure of an adjuster on the car you're considering, there is always the chance the adjuster was replaced with an identical flawed one if that's all that was available.
Spend some time reading the sticky.. it will give you most of the information you need to make an informed decision. You originally asked if there was a reason not to consider a "Launch" vehicle - without knowing the real status of the Variocam adjusters in the engine - IMHO there is a reason not to consider the vehicle.
