Air Suspension stuck in low level: "not possible" going up.
#46
Here are a couple videos of the self leveling ride height increase and the escaping (air / nitrogen?) sound. You can hear the pump run, while at the same time it deflates. The vehicle is not turned on, just keyless entry in proximity. Planning on taking it in tomorrow.
Don't let compressor to overheat/ burn - or you will need to replace it as well. Pull the compressor fuse if you have to.
#47
well, still some strange behavior going on. The shop isolated all 4 struts to 80psi, let it sit overnight. They said the FR dropped quite a bit an also the FL dropped 4mm the next day.
However, to be sure it was the strut and not a bad connection, they did a second test, disconnected and reconnected everything again and made sure the fittings were tight, aired it up to 85psi and soaped it up and check the strut, top of the strut to be sure there were no leaks.
14 hours later, little to no drop on either front strut. only a very slight drop and exactly equal on both sides. 820 mm to 800mm (I think he said mm?) however, not enough to be the culprit or least not enough to constitute a new strut or two. Rears have been fine and not moving at all. They are using shop air and not nitrogen though.
They are throwing out the first test to a bad fitting connection. They said the valve block was good, so I'm guessing it might be the line? perhaps the line or connection to the strut was bad and all the nitrogen was escaping thus causing the system to not be able to raise the car. Maybe that's what the noise from the video is from? I'm really hoping that's what it is. Still investigating.
#48
Depends on what's leaking. Possible leak points: air spring, a top mount seal, inlet valve seal, a top o-ring, and a lower o-ring. I've had the top mount seal leak before, part 958 343 018 20. That was found to be split upon disassembly.
#49
I'll get an idea of cost and rebuild labor and compare to a new strut and likely just do the FR and go from there.
#50
#51
I believe with PIWIS (Porsche's tester software) you can read the amount of Nitrogen in the system - i think it should be arroung 120 liters, So if you fill the system and next day you have 100 - than you have a leak in connectors. Does your shop have access to PIWIS to do the reading ?
I think they were going to fill the system with Nitrogen themselves. They mentioned using their Race Nitrogen. Would that be compatible with Nitrogen 5? Otherwise, they might take it to the Dealer.
Otherwise, there are some full struts that are priced around $1k each at Sonnen Porsche if all else fails https://www.sonnenporscheoemparts.co...PWxheWVyXzQ%3D
Porsche of Tampa as well, a little higher: http://www.porscheoftampaparts.com/P...-50-594196.htm
also that rebuilt one, but they are out of stock: https://www.suncoreindustries.com/p-...e-cayenne.aspx
#52
Nitrogen 5 - refers to some purity level - http://www.airgas.com/p/NI%20UHP200
It's probably relatively cheap to get proper gas if you call your local Airgas
When I had kegerator - I used to get "medical grade" co2 for my beer - was only couple $ more than "welding" grade. medical grade gas probably helped with hangovers
#53
Great info! Although, I have contacted Autobahn Porsche and Sunset Porsche, both dealership service centers said they only service the system with Straight Air, never heard of using Nitrogen.
#54
So they don't follow Porsche's workshop manual? It's clearly specified in the manual. Hopefully you asked an uninformed service advisor!
#55
Not questioning anyone’s expertise but this is the answer from Sunset. “Hi Darien, I asked a few techs and they said it is filled with straight air. Not a single tech has heard of it being filled with Nitrogen.”
Can you post the reference from the 958 Workshop Maunal?
#56
https://www.6speedonline.com/forums/...ml#post4639818
#57
WM 4301IN BLEEDING AND FILLING THE LEVELLING SYSTEM (CAYENNE, CAYENNE GTS, CAYENNE TURBO S, CAYENNE S, CAYENNE S E-HYBRID, CAYENNE TURBO, CAYENNE S DIESEL, CAYENNE (3.0)) > BLEEDING AND FILLING ONE AXLE > BLEEDING AND FILLING THE ENTIRE AIR SUSPENSION SYSTEM AND PRESSURE ACCUMULATOR
Information
Only nitrogen 5.0 may be used for filling the air suspension system. Available by requesting part number: 999.917.303.01.
#59
That's sad if your quote above is true. Whatever dealer that is, they need some new "techs". Unless he surveyed the lot attendants... then that info might make sense.
#60
