Air Suspension stuck in low level: "not possible" going up.
#31
What year is your Cayenne?
#32
Received 1,149 Likes
It is 2011 Turbo. I don't remember the total. The work was started by an independent and finished by Porsche Langley (BC, Canada). I'm kicking myself because the car was dropping overnight since 3-4 years ago, and I just thought it was normal, and it only got to the point of showing error messages after the warranty expired, and that also only happened at sub-freezing temperatures. I shoukld have brought it in while it was still on warranty. But anyway, don't want to thread-jack. I only brought that up because in my case it also started with front passenger side corner leaking.
#33
My understanding is suspension problems in sub-freezing temperature - means moisture in the system. I saw some threads on Toureg forums about people disassembling the pump to extract and dry out silica gel - but that was the previous generation, don't know if Nitrogen filled version has silica gel. In your case, it took 3-4 years for system to leak, maybe it's worth doing "replace silica gel and refill with Nitrogen" service every couple years or before every winter.
#34
Was it parked outside?
#35
#36
Got my car back from a reputable German repair shop today. They ran out of time and I have to take it back next week and still have not identified the issue, but here is what we found so far: (I'm paraphrasing from a phone call, so please excuse my interpretation)
- Fault 0284: Control position not adjustable. Vehicle too high or too low. (generic fault).
- Battery system reset.
- FR strut 10MM lower than rest of vehicle. They said they could not detect any leaks in the strut unless it is very small.
- Next step: Check strut air lines for leaks.
- Fuse checked: OK
- Relay function checked: OK. They said they would replace the relay since its cheap just in case. I have not driven it yet to see if that makes a difference or not.
Interestingly, I got a yellow headlamp sensor fault message on (or something similar) the other day, which means it could be the level sensor. So perhaps that might be the culprit.
My guy said the cold weather causes the Dessicant bag to freeze up which in turn causes the pump to fail, at least temporarily. It could cause damage if the compressor keeps trying to work and overheats while the bag is frozen. Not sure why Porsche could have overlooked such a weak link for cold weather. Seems quite prevalent.
If anyone else is having this problem, first simple things to check would be the fuse and the relay (which is in the trunk area).
- Fuse checked: OK
#37
I have a 2011 turbo. I've had my pump fail due to an internal valve solenoid failure so all 4 corners were dropped and the vehicle could not raise above low level. This had all kinds of recorded faults which pointed to the problem of a failed vent solenoid valve in the pump itself. New pump cured that issue. Couple years later I had the valve block replaced; it likely should have been replaced at the time of the pump failure. My valve block pending failure caused no failure/fault codes but I noticed the front right strut would make an air hissing sound and the strut would lose the most height with the right rear dropping slightly, too. This was most prominently noticed when lifting the left side of the vehicle to change wheels - the right front would collapse significantly with the air hissing noise, versus no collapse elsewhere. The valve block replacement cured this problem. In both of my cases, the struts were checked and not found to be leaking.
#38
Also, the 958 system should be filled with nitrogen 5, not standard shop nitrogen.
#39
- Fuse checked: OK
- Fuse checked: OK
#40
Thanks for the tips, i'll pass the info along about the strut and valve block. I think they are more experienced in the older Cayennes than the newer ones, so that was his experience offhand with the Dessicant bag.
I've heard the front right lower with an audibly loud Pshhhhhhh as if it was venting and watched the whole front end drop to low level at times. Would a leak be that loud or is that perhaps just part of the lowering process of some sort? Only did it a few times.
#41
I read some account where Nitrogen reload at dealer fixed an issue.
#42
Here are some pics of the disassembled compressor for toureg (similar to 955/957) showing desiccant and rust that started to develop. It's probably not a manufacturer approved procedure - but the guy says it took him couple hours and fixed his issue.
I know we are talking about 958 and it is the Nitrogen filled system. But maybe compressor on 958 is similar. If 958 system leaks out Nitrogen - it probably gets replaced with air from the atmosphere and with air comes the moisture.
#43
#44
Now I have never personally disassembled a compressor on the new cayenne but I'm pretty sure there is no desiccant bag in the air suspension on your cayenne. The system is sealed and inflated with nitrogen, I'm pretty sure there is no need for a desiccant. It sure sounds like a leaky front bag to me. I've seen it on the 92as quite a few times, always the passenger front for some reason. The only thing that causes one of the corners to leak is air (well, nitrogen to be exact) moving out of the air bellows on that corner. Either its leaking out into the atmosphere or its leaking back through the valve block. I The proper way to diagnose is a leak is Porsche has a factory tool thats screws onto the air lines at the valve block and you manually inflate the air springs. This isolates the air spring and the line from the rest of the system. If that corner still drops when the strut is isolated there is a leak in the strut or the line, simple as that. A leak in the air line is almost of heard of (but i have seen it once on a panamera.) If that corner does not drop then its likely you have a problem with the valve block.
I've never heard of a Dealership goodwill repair. I doubt they would go for it since my car is so far out of warranty, what kind of situations would qualify?
#45
Here are a couple videos of the self leveling ride height increase and the escaping (air / nitrogen?) sound. You can hear the pump run, while at the same time it deflates. The vehicle is not turned on, just keyless entry in proximity. Planning on taking it in tomorrow.
https://drive.google.com/open?id=1it...xRNeW3hDodkzh_
https://drive.google.com/open?id=1Ap...C9glXcvZUHt2YJ
