Ashtray phone mount
Ashtray phone mount
While discussing a 3d printed cup holder sleeve solution similar to (but way better than) tequipment's option, several members expressed interest in a phone mount that takes the place of useless ashtray/storage insert.
The first and by far biggest step was modeling a plug that will fit in place of the factory ashtray (or storage bin depending on your option.) Once that plug is right, adding a mount to the top of the model is trivial.
What I have below is a proof-of-concept modeled and printed. I'll be refining it so it has the contours to look reasonable when not installed, but functionally it fits well and is snug.
Now, I'm looking for input on what kind of mount you guys would like to see attached to the top of this. In my mind, I'm thinking a minimalist arm with one of those 17mm steel ***** would do the trick, but I'm totally open to suggestions.
Anyway, here's what I have so far:
The following 2 users liked this post by AGARubberDuck:
ceeul8r (09-23-2023),
Wallace1972 (03-08-2024)
Received 1,140 Likes
I think you want the arm to reach back over the lid of the compartment, moving the phone back toward the dash. Adding a mount to the idea above might result on the phone being in conflict with the shift lever when it's in PARK - the two might be occupying the same space..
I recommend that the arm have a pivot/rotation point, where it meets the base. Taking into account strength or lack thereof as a limitation, would it be possible to have a ladder-look to the arm, so as to be able to see through it? I'm not talented enough artistically to say whether that will look good, however. Just thinking about for when the phone is not there.
Here is my $0.02. Is this pivot ball design a means to provide an attachment to an existing phone mount accessor available which we have to buy as well? If so, can we know which product and see if that product can accommodate all/if not most cell phone shapes.
I use a phone cover/sleeve. A pivot ball design will require me to buy a magnetic attachment solution from phone to a pivot ball which I hope to avoid as an user. Is a "vent fin" design also a possibility so we can use/buy "air vent" phone holders to attach cell phone to this piece?
Actually - there is one company that sells Cayenne specific mounts (mount to the side panel of the console - no screws, tape or other damage to the leather..) and it's made up of 2 pieces. The mount to the car, then a mount from that mount for the phone. They screw together - standardized screw hole pattern allows them to sell a variety of phone specific mounts that fit the one common car-mount.
Lets see if I can find it (I have one in my P!G - works great..)
Found it: http://www.proclipusa.com/
The car-mount selection: http://www.proclipusa.com/vehicle/da...e-cayenne/2011
Different "standard" phone mounts for different phones: http://www.proclipusa.com/product-finder/device
The phone mount I bought: http://www.proclipusa.com/product/51...e-lighter-plug
I'm thinking if you simply provided a flat surface with the dimples in it to screw the screws holding the phone holder to the base - you'd provide a great alternative to the ones Proclip is selling. I have the right-side mounted one, and it does block access to the HVAC controls for a passenger.
I can measure the mounting plate for you if you'd consider this design.
Following. I've been setting my iPhone 6+ in the ashtray since I got this thing. Happy to see someone coming up with a solution!!
As far as a 'vent fin' type mount, I don't think I'd make that exactly, but more of a sturdy piece with a hole where a machined screw could be used to mount whatever you'd like, more robust than the vent clip style.
I could be pretty easily persuaded to change my mind, just my experience with vent clip mounts allow the whole phone with mount to flop around when driving.
Since this is going to end up being a development journal of sorts, here's another pic. Currently printing the mock-up with the mount arm and 17mm ball (plastic, of course to gauge fitment and positioning.)
In this pic you see the ashtray plug on the left-hand side, just beginning to print the arm. Extending to the right is just temporary support material that breaks away when finished.
One of the biggest problems to watch out for is vibration. The way the weight of the phone extends as a 'lever' against the mounting point is a problem if there's even the slightest amount of vibration. This means however the phone connects to the mount AND how the mount connects to the car REALLY have to have a solid fit. Otherwise you end up with a pendulum effect and annoying movement of the screen. This, I've learned, after countless numbers of mounts combinations in many different vehicles. My latest GTS included.
