958.1 958.2 Closing Trunk Lid
Hello,
I'm currently driving a 958.2 Cayenne as a loaner while my 958.1 is in for repairs at my local Porsche dealer.
I noticed the .2 model i can close the trunk by pressing the button on the drivers door. Can this be programmed for the .1's ? This would be extremely useful.
I believe their is a module that does it for the key fob for a .1 however i would like to have the ability of using both. Key fob & drivers door button for trunk closing.
I am bought the PLUSOBD DVRs&Cameras For Porsche Cayenne Camcorder Dash Cam Car DVR With 4 Windows Trunk Close Function, it work for 958.1, but you need to ask them how to install and make sure they send the right adapter for your car.
https://www.aliexpress.com/item/DVRs...311.0.0.toQ1d6
Be aware that some of the modules that work with the liftgate connection may have problems if you also have keyless entry. I tried one and the module and the keyless system wouldn't cooperate with each other. Essentially the add-on module was getting out of sync with the keyless system, leading to all kinds of random 'key missing' errors. Whether or not this could be overcome, I don't know. My english/chinese tech support tolerance is NOT high enough to suffer figuring it out.
Interesting. My 2014 (a .1) has this button. Press once to open. Press and hold to close.
I also have Entry and Drive - I wonder if that's part of the package? I figured all 958's had this button.
My 14 was a .1 and my 16 is a .2 both had entry and drive and they both worked this way.
