958 Cayenne changes from normal steering wheel to multi-function steering wheel help!
My 958 Cayenne came with normal steering wheel, but I have planned to change to multi-function steering wheel.
https://cimg6.ibsrv.net/gimg/rennlis...02b039f31d.jpg I got one from my friend. It is a used MF steering wheel which comes with a set of slip-ring and whole control column. https://cimg7.ibsrv.net/gimg/rennlis...5a7d96be5a.jpg Today, I have installed the new MF steering wheel. All the connector work perfectly, but it turns out that I cannot use the whole MF button on the steering wheel (The backlight is on and paddle shift works fine.) I guess that I might need to get an activation code of MF button or something. Does anyone have this kind of experience? Please help me. Thanks a lot |
Yeah you'll have to get the vehicle coded to use the new wheel.
Are all the vehicles pre-wired to use the MF steering wheel or do you need a new wiring harness, too?
Originally Posted by skiahh
(Post 13082270)
Hi
[QUOTE=varit7530;13082122]My 958 Cayenne came with normal steering wheel, but I have planned to change to multi-function steering wheel.
https://cimg6.ibsrv.net/gimg/rennlis...02b039f31d.jpg I got one from my friend. It is a used MF steering wheel which comes with a set of slip-ring and whole control column. https://cimg7.ibsrv.net/gimg/rennlis...5a7d96be5a.jpg Today, I have installed the new MF steering wheel. All the connector work perfectly, but it turns out that I cannot use the whole MF button on the steering wheel (The backlight is on and paddle shift works fine.) I guess that I might need to get an activation code of MF button or something. Does anyone have this kind of experience? Please help me. Thanks a lot[/QUOT |
Any joy with your steering wheel controls
Hi there
I was wondering did you manage to get the steering wheel controls to work?, and if so what did you have to do to get them to work ? iv also bought a Cayenne which didn't come with the controls and wanting to upgrade the steering wheel too I would appreciate it if you could share your experience and knowledge about it thanks Bill
Originally Posted by varit7530
(Post 13082122)
Hi there
I was wondering did you manage to get the steering wheel controls to work?, and if so what did you have to do to get them to work ? iv also bought a Cayenne which didn't come with the controls and wanting to upgrade the steering wheel too I would appreciate it if you could share your experience and knowledge about it thanks Bill Quote: |
Perhaps the multi-function wheel you received from your friend is left-hand drive?
Just kidding, glass of wine made me do it. best of luck with the install! |
