2011 + DYI brake pad replacement
Looking for help, I replace pads on my 997 and 996, very easy, then I looked at my 2011 Cayenne.....
I searched for 2 hours on the internet to find a DYI and could not find one. After I remove the two bolts, yellow arrow, what should I expect?
Is this a two person job, where one (preferable a weight lifter) is holding the calipers while the other removes and re-installs the pads?
Is a special tool required for the brake pad clip?
Thank you
Thank you
Bump. Any insight into how this went? Looking to change pads myself.
Received 1,140 Likes
There are LOTS of DIY's on this - searching should turn them up.
Also - a clue - the MODEL of your '09 might well make a difference. Different model Cayennes use different brakes. The difference can be significant, and what's shown for one may not be at all like what is used on another.
Perhaps adding your name, year/model/location to a "SIG" might be useful. That means people won't have to guess..
