Cayenne Diesel - Performance Upgrade?
Congrats on joining the club
Map 7 is, I believe, what Greg has been using until recently and has been pleased. I ran a tank at Map 8 and a second at Map 6 and will be going back to 8 and staying there.
One of these days I hope to find some cheap dyno time and get some real numbers on the power.
If you read my thread on 6spd I mention a couple of incidents where I smelled burning oil, but that was motor oil and not diesel. That's only happened twice and I don't think it has anything to do with the tuner. Otherwise there is no smell difference from stock and the exhaust is still just as clean.
I also mention that it sounds to me like there is more clatter, but my wife doesn't notice any difference and people continue to be surprised that its a diesel when standing next to it while running.
FWIW; I installed my BlueSpark box in December. To date I've used Maps 8, 7, 6, and 0 without noticing either of those issues. Nothing even close to the old school diesel clatter is evident unless/until one actually opens the hood. Even then its comparatively insignificant. Besides the astonished looks when I tell them this is a Porsche Diesel, their jaws drop even further when a finger wiped across the inside of a tail pipe extension - comes out clean.
//greg//
//greg//
I noticed just a tad more light throttle diesel clatter on mine. Asked Greg about it and he wasn't sure on his. It's not enough to even be bothersome and my hearing is still quite sensitive to things but I was more concerned it could be perhaps running a little too lean for mpgs . . . a diesel variant of pinging. I have been assured that is not the case. Meanwhile I continue to enjoy a real kick in the *** on setting 7 with my foot in it and got 36.3mpg at consistent 68mph cruise the other day. That is just plain amazing. We're going to be able to go all the way to our cabin in CO and back on one tank of fuel and 0-60 is now down close to 6 secs.
Best $400 I've spent . . .
Yes I installed it myself. It is incredibly simple. Go take a look at the first post in my thread on 6spd in the 958 forum (sorry I don't know the linking to other forum policy) and I talk about the install and include pictures.
Never done more than a test drive in a (955) CS so I have no idea how it compares from personal experience.
//greg//
I believe that sticker is related to the All Season tires warning. Since the Cayenne's can be optioned with all season (mud & snow) tires the sticker is there to warn you about exceeding that speed when using M&S tires. Don't believe it has anything to do with the actual speed capability of the vehicle.
One thing I noticed in yesterday's triple digit heat is my Cayenne was a little doggy on throttle response - something I hadn't noticed before. However, this is my 1st experience with my Cayenne and triple digit heat period. Next time, I'll dial the Bluespark back to 0 and see if it's the Bluespark or just some high heat phenomenon with my Cayenne [??]. Just seems to be taking turbo lag to an extreme feeling.
Beyond that, I don't race people generally on the street unless they deserve it but, a couple days ago, a V8 X5 would not freakin' leave me alone on 2 consecutive stop lights so he got introduced to Bluespark and diesel torque. I absolutely dusted him. Wasn't even a race. I knew I would get him but did not know just how badly [??].
Again, though the 0-60 is about a second quicker on setting 7 which is nothing to sneeze at, 0-40 on these was already strong and it is now WAY strong.
I know our NA 996 vastly prefers 45 degree days to 100+ days. So far the low 90s is all I've had the CD in and I haven't noticed any significant difference in performance (which is actually a surprise to me).
Yeah, I understand that "generally" but I come from a Touareg TDI and it did not have this problem when hot . . . or at least not nearly to this extent. I think it was severe enough that it was indeed "a problem". Just don't know if it was Bluespark induced or something with the Cayenne. Here in Kansas, bound to be plenty more triple digit days so I'll find out.
Just didn't know if anyone else has seen it yet or not?
//greg//
Not having actual numbers I would guess that part of that ECU map difference is a higher boost pressure in the Cayenne which means it wants more air and would exacerbate a "bad air" problem. Of course the BSP+BC specifically works with your boost sensor (though I'm not clear exactly what it is doing) and would likely extend the impact even further.
So yes the BSP is probably making you notice it more, but it's a function of how much air the engine is wanting rather than a problem with the BSP itself. This is why when people start upgrading FI engines a CAI and larger/better Intercooler are on the short list of things that need to be done.
