Sponsored By:
Sponsored By:
Cayenne Diesel - Performance Upgrade?
Old 06-01-2018, 09:28 AM
  #226
Eskimo1
Eskimo1's Avatar
Originally Posted by Hawkpilot6060
It is in the low 80’s here now, warming up.
If you haven't had a car with a turbo before the heat and humidity isn't doing you any favors, that's for sure. 8.0 just stomping the go pedal from the start isn't too shabby though!
Old 06-01-2018, 09:40 AM
  #227
Eskimo1
Eskimo1's Avatar
Originally Posted by Joewharton2
Nice #s. Would like to go with Malone but still have a lot of warranty. Must be able to take it off to take it in to the dealer if problems.
The owner of the car whose times i posted had a frank conversation with his service advisor prior to putting the tune on the car, and they said that if possible he should put the tune back to stock when bringing it in just for plausible deniability, but that unlike some other car companies, Porsche (at least that dealer) isn't on a mission to deny warranties - their goal is to find the problem and fix it, especially on a part that's unrelated to a tune or has a history of failing. They're not going to go digging to see the flash counter in the PCM. The owner isn't too worried, since the driveline on the 3.0 is well-regarded as being stout, and another 70lb-ft isn't going to break it. I tend to agree.
Anyone who buys a piggyback box thinking they have less chance of breaking something or is invisible once removed is fooling themselves, IMO. It's a fact that a full ECU tune is the better way to extract safe power, and even my previous 2004 Chevy truck with the old-school 4L85 transmission had input shaft torque sensors available in the ECU to be read. Our Aisin 8-speed surely has sensors that can log how much power is coming into the transmission from the engine.
There's a risk with any modification.
Old 06-01-2018, 11:13 AM
  #228
chsu74
chsu74's Avatar
This is where a 12 pack or case of beer helps when bringing in your car for service or warranty claims. Did that a few times. Now I get the nicer loaners and benefit of doubt on nagging issues.
Looking for a good tune still. There is still time. Tune for newly released cars takes about a year to go to market. I am patient.
Old 06-12-2018, 05:28 PM
  #229
Elberoth
Elberoth's Avatar
I just measured 6.791s 0-100km/h on my chipped 3.0 TDI (that probably translates to sth like 6.6s 0-60mph). I have power braked the car. Power braking is worth about 0.4s.
The car did 305 crank hp on Maha dyno. The factory specs for my 2012 245hp model are 7.8s 0-100km/h, so we are talking about 1s less thanks to the new tune.
I have used Car Scanner app for iOS paired with WiFi OBD2 dongle for data acquisition.
Old 06-12-2018, 08:18 PM
  #230
Kayaknfly
Kayaknfly's Avatar
pretty good improvement!
which tune are you running?
How does it drive/compare in regular driving? IE lag, hesitation, noise etc?
Old 06-13-2018, 03:42 AM
  #231
Elberoth
Elberoth's Avatar
I'm running a custom tune from a local specialist. The car was flashed via the OBD2 port. The car drives like a stock - afterall, you have the stock turbo, IC etc - it only pulls harder when you floor it.
Old 12-10-2018, 10:37 PM
  #232
Hawkpilot6060
Hawkpilot6060's Avatar
Default Diesel
I just emailed Malone Tuning to ask the status on the stage 3 tune for the 3.0 diesel with the GTB2566VK Turbo. From reading some of the VW forums, they are getting an easy 340-350hp. I will post up a response when I get it.
Old 12-10-2018, 11:05 PM
  #233
Hawkpilot6060
Reply so far from Malone.
Hi Rick,
We have no problem tuning for these kinds of setups and have been doing so for awhile, but we don't plan on stocking turbos for them. We're in Vancouver so land is very expensive ($400/sqft+) and prefer to focus on R&D rather than selling parts.
Thank you,
Owain
i replied back, will post update.
Old 12-11-2018, 08:39 AM
  #234
Hawkpilot6060
Reply from Darkside in the UK as to a turbo upgrade for the diesel. Hi
You have the Turbocharger 95812302520 which is a GTB2260VZK
[img]blob:https://rennlist.com/91d36ced-0e9f-4ff3-8bcb-0fa9e8c1f289[/img]
We have an upgrade here
https://www.darksidedevelopments.co....k-housing.html
We do not have any other upgrades available for your model, but most customers would go for a DPF Delete and maybe an intercooler upgrade, as well as a custom tune
/darksidetdi
Darkside Developments
Unit 1 Carbon Court
Springvale Road, Barnsley
South Yorkshire, S72 7FF
United Kingdom
01226 827999
Old 12-11-2018, 05:34 PM
  #235
Hawkpilot6060
2nd reply from Malone tuning. I am going to call one of their tuning shops in Florida tomorrow and see if they could install the turbo and the tune!
Yes as long as the mechanical work is solid we'll have no problem tuning it.
Old 01-24-2019, 11:13 AM
  #236
Blue Chip
Blue Chip's Avatar
Reading through this - it seems like the Malone Tune is still performing really well and (seems) is setting the standard.
Considering a tune and exhaust option on my '13 CD.
Old 01-25-2019, 03:21 PM
  #237
SeamusH
SeamusH's Avatar
In late 2013 I factory ordered what is probably the most highly equipped Cayenne Diesel in the country (>$90k MSRP). I wanted a comfortable long-distance DD for 20k+ per year, I added every option that would help make a great long distance cruiser: adaptive cruise control, thermal glass, Burmeister, upgraded leather, etc. I was originally going to order a GTS, but I loved the lazy low torque and 800 mile range of the Diesel. Within a month of getting the CD I installed the Bluespark box (fuel rail and turbo boost) based on reviews here. I would regularly get 35mpg on 200+ mile trips and it was fun to drive.Like many others I was tempted with the $11k and extended warranty attached to the fix. The combination of cold rattle, dangerous hesitation from a stop, and all the other issues mentioned in this forum made me immediately regret the decision. I tried the Bluespark unit again at a wide variety of setting and within a week took it off permanently. It did not fix the underlying issue of an engine tuned well out of its sweet spot by VAG to minimally meet emissions and avoid a very expensive 3.0 TDI buyback. I believe that turning up boost and fuel rail pressure on the “fix” tune is courting disaster, something expensive will break and likely quickly.After a bunch of research, I took the plunge with the Stage 2 Malone tune and installed it earlier this week. I don’t want to remove exhaust emissions equipment or overly stress an engine that I plan on adding another 100k to. After a few days I can say that the tune fully meets my expectations, the engine performs better than the pre-fix tune plus Bluespark. I expect the engine to last longer that it would on the post fix tune (unless you are always maxing out the turbo).The one remaining issue is the transmission “fix” that causes it to hold gears to a ridiculous extent when cold. Malone is working on this, and as soon as it is available, I will install it.
bad_mutha (10-31-2021)
Old 01-25-2019, 04:49 PM
  #238
KBell
KBell's Avatar
Beautiful. Thank you for the update.
Old 01-25-2019, 05:05 PM
  #239
visitador
visitador's Avatar
Originally Posted by SeamusH
IThe one remaining issue is the transmission “fix” that causes it to hold gears to a ridiculous extent when cold. Malone is working on this, and as soon as it is available, I will install it.
But, there is a fix for that: https://www.clubtouareg.com/forums/f...ml#post2017583
I believe he also works closely with Malone
Old 01-26-2019, 12:18 PM
  #240
SeamusH
SeamusH's Avatar
Yes, I've been following that thread as well. Seems like it is a revision to the pre-fix ECU tune, which would be a huge improvement. Malone sent me this in an email "at this time we're just tuning the ECUs, but we should have transmission solutions in the near future as well." I'm going to hold off on this for a couple of months as I would sooner get a TCU tune from Malone that is optimized to work with their ECU tune.
Quick Reply: Cayenne Diesel - Performance Upgrade?
