10 Beeps? '15 Cayenne Diesel
Very odd behavior, searching has not turned up anything and my lead dealer tech is stumped. My '15 CD is rolling along great at 107k miles. Everything working fine. While driving, and not correalated to anything I can figure out, the car does exactly 10 beeps in a sequence. No lights, messages, anything.
Why?
Why?
My Q7 TDi beeps when I hit 100 mph.
But it's only one beep, if I remember correctly, and it should be configurable.
Do you have a sense of where the beep is coming from? Under dash, radar detector, rear cabin area?
Anything else common? Even *where* it happens? Near large power lines?
@lml999
The beeps come from the dash.
When I have my phone paired, and I get a text, the car does two double beeps and the message icon comes on the PCM screen. Right?, this is normal. What I'm experiencing is the same beep as the text, but 10 in a row, with a steady cadence. "Beep, beep, beep, beep, ....x10.
I found the speed limit settings and set both of them to 100. Which I've never been any where near. In the last couple days, we drove almost 1000 miles to the east coast, and the 10 beep sequence happened 4 times in that day and a half of driving. So far, I can not correalate it to any common factor, and having been an automotive powertrain engineer for 25 years, you can bet I've thought it over. Someone mentioned low voltage, but then I would expect it at low revs, not on the highway. But, maybe it's when I temporarily let off the pedal. Stranger things have happened.
I'm flumoxed!
I'm flumoxed!
