Cayenne Coding - The Ultimate Guide & Discussion
#1591
I think in the 2015+ models, you can't permanently disable the start/stop? In the Engine module, there is a coding for the start/stop function. I set it to Inactive for now. Haven't test it but I'm hoping I can finally turn off the LED light on the console button.
Start/Stop is located in both the Engine and Gateway module. I've deactivated it in both. Will test and report back.
Attachment 1345049
Attachment 1345050
Edit: tested and I still need to keep the buttom on the center console activated. Maybe only effective on 2015+ model?
Attachment 1345049
Attachment 1345050
#1592
Just read you have a 2019 so not sure if possible on this model
ctguy (02-27-2024)
#1593
Anyone know how to code out the PTV+ Rear Differential. Mine has issues so I pulled the fuse for it, but I get a stupid message every time I start the car.
X431
X431
#1595
X431 just search for "LED" front end electronics I think
#1599
#1600
Take the time and use the SEARCH function.
https://rennlist.com/forums/992/1275...peedo-tip.html
See specifically reply #3
siberian
siberian
#1601
siberian
siberian
thanks
#1602
#1604
Thank you. There are many posts about how to change the model logo on the instrument cluster screen. I am looking for someone who knows how to change the model logo on the PCM Screen.
