Cayenne 958 - 2011-2018 For newer Cayennes than the 955/957 series
Series II
Sponsored By:
Sponsored By:
Variocam Lift Valve
Old 07-10-2019, 11:51 PM
Teddybehr
User
Teddybehr's Avatar
Default Variocam Lift Valve
Hi,
My 2011 958 Cayenne S have a check engine light (yellow) warning.
My engine is running rough after 10+ km or so or just after a restart.
Went to the dealer. After insisting on, at least checking the codes, the "service technical expert" told me that is was the vario lift ... well guess he meant: Variocam Lift Valve.
He told me that I can drive it normal usage. No damage will occur to the engine or other components what so ever.
My scheduled repair is only in 3 weeks. (earliest possible appointment because they are loaded).
The car is on CPO warranty.
Should I thrust him about the "no damage will occur" claim?
Thanks alot
Just FYI, I had PASM problems and now it's dropping again and the same guy told me that PASM components are not covered by the CPO. Told him that they changed 2 compressors, 2 bloc valve and 2 air springs within 2 years and they were all covered and only shocks are not covered. That is why I ask you guys (that I trust more) the real answer for the variocam thing
Teddybehr is offline
Old 07-11-2019, 02:03 AM
deilenberger
Moderator
Do you know if the variocam bolts have been replaced? If you have no clue what I'm talking about - go read the sticky for people thinking of buying a used 958 Cayenne.
deilenberger is offline
Old 07-11-2019, 02:38 AM
Teddybehr
User
Teddybehr's Avatar
Yes I am familiar with the recall and it has been done 2 years ago and confirm by a CPO inspection and recertification 1 year ago.
I will check and comment the thread but some people from time to time ask me if I am selling my car because they want the "Sound of Porsche naturally aspired V8" from the S and GTS (GTS sound way better ) and they stop putting the V8 on the S and GTS in 2013 if i am not mistaken.
Are you tell me that I should not drive it meanwhile or go to the dealership and take it a step further?
Old 07-11-2019, 03:03 AM
quickster2
I'm making an assumption here that your truck idles roughly but once at cruising speed/rpm all is normal??? If so it is most likely a valve lift solenoid and not vario-cam. If that is the case then the dealer is correct in what they told you. The naturally aspirated V8 (S & GTS) went away after 2014.
quickster2 is offline
Old 07-11-2019, 11:56 PM
Teddybehr
User
Teddybehr's Avatar
Right assumption!
Thank you very much for your insight and the info (I will sleep a bit less stupid tonight )
Old 07-12-2019, 03:57 AM
quickster2
I had this same issue on mine. Hope it works out for you. I would try to minimize driving time and get it fixed as soon as possible.
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
