Cayenne 958 - 2011-2018 For newer Cayennes than the 955/957 series
Series II
Sponsored By:
Sponsored By:
Transmission fluid change procedure
Old 06-29-2019, 06:07 AM
pelensky
User
Default Transmission fluid change procedure
I have a 2012 CTT and would like to change the fluid and filter. I will be using an icarscan tool for reading the transmission fluid temperature. After a search, I found on DIY instruction but it was not very clear.
Is there a good DIY for Transmission Fluid Change somewhere?
pelensky is offline
Old 06-29-2019, 09:02 AM
Tom M
User
When I did mine I used the instructions on AllDataDIY.com. There's an annual fee but it's well worth it if you're going to be doing your own wrenching and if you search around you can find a discount code to knock a few bucks off the cost. I only drained the transmission itself and replaced the filter but didn't open the rest of the system figuring I'll flush it a 2nd time after running it for a bit.
Changing the filter isn't terribly difficult but it can be pretty messy when dropping the pan as even though you've already drained the fluid all of the remaining fluid comes out. Had quite a bit of cleanup even though I had an extra large catch pan.
Youtube had some helpful video as well. The biggest help was making a pressure tank to refill the transmission once everything was buttoned up.
Tom M is offline
Old 06-29-2019, 09:53 AM
Slickdvl
User
All data calls for a specific tool and temperature testing - this is one thing I may take elsewhere to get done
Slickdvl is offline
Old 06-29-2019, 02:40 PM
deilenberger
Moderator
The fill tube is about $12 - same as a VW one. You do need something like a Durametric or IcarScan to read the transmission temperature - but you need one of these anyway if you're at all serious about DIY work on the Cayenne.
deilenberger is offline
Old 06-29-2019, 10:50 PM
garrett376
C4 Specialist
This pressure filler includes the necessary adapter and makes it a really easy process to fill the transmission quickly and accurately:
https://www.ecstuning.com/b-schwaben.../007311sch01a/
garrett376 is online now
Old 07-04-2019, 11:12 AM
rich022
User
There is a very good DIY for a transmission change for our cars-either on this forum or 6speed. google search will pull it up. Lot's of pictures etc.. I've bought all the necessary stuff including the pump+VW tools+VW fluid+filter.- I went with the Mityvac MV6410 which came with the tools.
rich022 is offline
s996 (07-04-2019)
Old 07-04-2019, 11:23 AM
kennyt
User
that MV6410 kit is not cheap so when adding all the costs up is it worth it to DIY? How much do they charge at the shop for transmission oil change?
kennyt is offline
Old 07-04-2019, 11:33 AM
Quadcammer
Super User
All you need is the mva585 for about 12 bux.
Id say for a full filter and fluid replacement, you'd be looking at 1,000 at a dealer and 800 at an indy.
Quadcammer is offline
Old 07-04-2019, 05:23 PM
deilenberger
Moderator
From a quote from a very highly regarded shop in central NJ
Originally Posted by BodyMotion
How many miles are on the truck? Do you want the transmission filter replaced or just the fluid changed?
To drain the pan and clean, replace filter, gasket, and fluid is $575 + tax
Old 07-04-2019, 09:05 PM
BrendonSF
The maintenance kit alone runs $450 at Suncoast. Seems like a very good deal.
BrendonSF is offline
Old 07-12-2019, 12:25 PM
Slickdvl
User
Slickdvl is offline
Old 07-12-2019, 02:44 PM
BrendonSF
Good find. Is this kit all OEM parts/fluid? The photo on the site isn't loading for me.
Old 07-12-2019, 03:04 PM
Slickdvl
User
No, the fluid is Ravenol and no indicator of who makes the other parts - i would be ok if itĺs an oem supplier
Slickdvl is offline
Old 07-12-2019, 04:49 PM
kennyt
User
Suncoast OEM kit $450 https://www.suncoastparts.com/product/PK958TRANS.html with 9 liters of fluid. It's a a good deal.
kennyt is offline
Old 07-12-2019, 05:44 PM
Mrg02D
User
How often should we be doing this?
Mrg02D is offline
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
