tow module...working?
Guys,
Installed all the factory tow stuff and "f" module from a used cayenne.
I hooked up my tire trailer with a 7 to 4 pin adapter. The lights work great but i get nothing on the dash. Is this due to the 4 plug thing or adapter or is this module not working?
Any thoughts?
Any thoughts?
Not sure what you mean by not working...... Mine works and I know for sure, but.. nothing shows up on the dash when you connect the trailer because my cluster doesn't have that light that indicates a trailer connected. However, if i pull out the light bulb on the trailer, right away on the dash window where you get messages, it says trailer light out. Thus i know it works.
Didn't try the light bulb test but maybe thats one way to tell.
My trailer lights working threw me off because I figured they wouldn't do that if the module wasn't working.
The lights working is one thing but making sure the shift points and all other changes are active is what I'd be concerned about. Same goes for making sure the alarm works if the car is off and the trailer is unhooked.
Its a bit trivial at this point because all I'm towing for the time being is a 500lb tire trailer, but just in case I need to pull my track car somewhere, I'd like the module working.
More concerning to me - the cooling system doesn't change because of 'trailer mode'. The grille shutters and thermostats still behave the same as they do without a trailer. Activating sport mode, however, opens up the cooling system and brings a significant change in coolant and oil temps. I prefer the throttle response of non-sport mode when towing, but want the better cooling, so I deal with the sensitive pedal. The firmer shifts are also better for the clutches in the trans.
Plugging in the trailer *does* disable the Lane Change Assist, removes the grid lines when reversing, and the aforementioned alarm system change, but that's it.
On 958, you should not need any programming if you got the used tow computer. New units require coding, but used ones "should" be fine. Such was my experience when I was trying to code the tow computer for F SANE IL with PIWIS - there was nothing to code, everything was already there.
On 957, you need to visit the dealer if you want all the functionality enabled.
To test, plug in a trailer - all you care about is the electrical plug in. The following should happen:
1. When you turn on left or right turn signal, you get the <=1=> icon on your dash blinking along with the side indicator. EDIT: This was a feature on 955/957 and may have been removed in 958. I'm not 100% sure here.
2. Rear parking sensors disabled, if so equipped.
3. Tail gate button on the remote will pop open the lock but will not open the tail gate with trailer plugged in.
4. When car is locked and armed, unplugging the trailer connector should set off the alarm.
Check and report back. 7-to-4 trailer adapter is fine.
So far, I did not get the icon on the dash.
I will have to review the other things though as I haven't checked those.
Mine came with it from the factory, so I think it should be working correctly (but who knows).
No go. Module is not doing any of those things but for some reason when you hook up trailer auto start stop deactivates. If it doesnt do anything with cooling or tranny programming then i may not mess with it
