21" turbo wheel center caps
Help....NEED 63MM Porsche wheel center cap
Guys, I am in desperate need of. 63MM center cap with porsche golden logo. I searched across the internet and cant find anything.
these are going ogoing new Vossen wheels. Vossen said size is 63MM. The stock caps of the 20 inch wheels are too big. Any idea where to buy the proper 63MM caps?
@biga1 Typically the center cap is measured at its outside diameter. Vossen provided the bore measurement...what you want is a centercap with the retainer clip measurements matching that bore, so the '65mm" measurement above is irrelevant.
For the Cayenne five spoke 18" wheels that I put on my Q7, I ended up buying blank caps and putting vinyl 4 ring logos on them (the Q7 has a different bore than the Cayenne). You might need to do something similar...find a blank cap that matches the Vossen bore, and add vinyl Porsche emblems. All this is available via ebay, and you might need to do some experimenting before you get the right fit.
Or there might be an OEM Porsche cap (non-Cayenne) that fits.
Hope this helps.
Hope this helps.
afriedrich (05-03-2022)
