CarPlay Retrofit in PCM 3.1 Cayenne 2013 ( With Pictures )
#947
#948
@konkab - how's the custom firmware coming along? Did you get any further with the Bluetooth transmitter?
Regarding steering wheel buttons and volume **** issues no any progress as well. It seems like this kind of "hardware" stuff is programmed in MCU, a separate STM32 chip on board that has its own firmware. I tried some hacks in the SOC firmware, but no luck yet.
Chinese guys sent me another firmware dated August 5, but I don't see any changes in it. Also trying to settle all these issues with the seller and their engineer, but no progress here as well
BW369 (10-04-2021)
#949
No any noticeable progress on firmware. I tried 60 FPS mod, but I didn't like how it worked. It feels like refresh rate of the screen doesn't match refresh rate of CarPlay and because of that it doesn't feel that smooth as it was on Joyeauto. Maybe on Android Auto it works better, but I haven't tested it yet.
Too bad that they decided to do this, and there will be no easy fix for these quirks. I’m getting used to some of them, but that steering wheel control is hard to overcome… in any case, I wanted to thank you.
Good luck in trying to figure it out. We are still hopeful!
And any firmware updates that you receive, can you post here?
Again, thanks!
#950
@Konkab
I have access to their technical team, if you like I can do a WhatsApp group with them and we will ask them to make the change directly in their software if you or anyone like to send me your WhatsApp in PM
have a nice day
sacaman
have a nice day
sacaman
#951
Thanks for your efforts on this @konkab.
Again, thanks!
Again, thanks!
I'll PM you now.
#956
So I mentioned a few posts back that I had a white noise and interference type noise which I didn't notice at the start. I have since swapped out the cable for aux from board with a high quality audio cable and from the connector to back of PCM again with high quality audio cable. The noises both remain, audio does seem a little better but it still has a harsh tone to it and this can be noticed on some songs with which vocals have been autotuned. One thing that is really annoying me and I wonder if its the source of the interference is just how strong the WiFi Signal is! Like I can be up stairs in my house a room back and my phone still is connected to car. Is there anyway to turn signal down, I would much prefer stretch to just cover the vehicle plus a little.
Videos of noises:
Videos of noises:
#957
I haven't noticed any changes.
I have the same white noise when connected to AUX2USB, but in reality I never make 100% volume without music playing. When music is playing, the noise is almost unnoticeable. Yes, this is a compromise between awful factory AUX and AUX2USB and to me AUX2USB sounds way better. I believe the white noise issue is inside of AUX2USB adapter.
Videos of noises:
https://youtu.be/1_TMz9lPJ7c
https://youtu.be/q88sG6KqUn8
Videos of noises:
#958
It would be great if someone with an unmodified unit could check for the noises I mentioned, white noise at close to max volume when wired/wireless and the WiFi interference noise at 60-70+ volume when using wireless CP/AA.
#959
This has nothing to do with the adaptor as I am no longer using the adaptor as I can't say I noticed any big improvements when using Android Auto Wireless, I will say after a long drive today audio has improved since swapping out the audio cable for something better. It's just a shame the connector(JST SH) on the board is so tiny as is the hole to pass through the cables out of PCM! Ideally I would prefer a single AUX cable from the board to the back of PCM bypassing the Molex Micro fit 3.0.connector.
#960
Cable is the same as delivered, the only difference is I have swapped out the aux cables between board and pcm3.1.
