New Campaign For AdBlue - Cayenne Diesel
Apparently there is a new campaign replacing something with the AdBlue system. I bought a 2013 CD from a dealer on New Years Eve. That night the CEL lit up. I ran the code with my Durametric and it was something with the catalyst.
Took it in last Friday, they identified it as a Nox Sensor issue. Took it back on Tuesday for the repair. Got a call today, and apparently in the time that my car was there, a new campaign was released for the AdBlue system. New parts came in today (which require dropping the exhaust). They think I will have the car back on Monday.
I'll share whatever they do once I see the write-up.
Check engine light came on. NOx sensor.
Took it in.
No cost. Dealer very accommodating.
The NOx sensor is down stream from the AdBlue injector.
All the extra spray from Ad Blue the cause of NOx sensor failure?
Took it in.
Failing adblue heater is pretty common and well known.
Is this a different issue?
Mine threw a P226D code - dealer is changing out the DPF and also ordered the DPF attached to it, in case the bolts snap when removing it. '16CD, 68k miles.
