Changing Cayenne Diesel Fuel Filter
Funny, about getting or thinking one needs new bolts. Might as well get new lug bolts every time one gets new tires.
The parts guy I had gotten the first fuel filter from at the closest dealer from me,had insisted that I'd need new bolts. I told him that I'll pass this time and if I need them I'd come back and get them. I'll never see him for another fuel filter again as I know that the VW Touareg Mahle or the Mann filters are the exact same, for 1/2 the cost as they do not come in the white Porsche origami-box that must cost $40.
post note: Interestingly, the rubber gasket was dark brown color instead of blue as shown in the pictures above. The one I swapped out was blue (original). I hope it's not counterfeit :-)
While changing the oil on my 2016 Diesel this weekend, I thought I'd take a look inside the fuel filter housing and suction out any water. After I removed all 5 screws and lifted the cover, I saw that the entire canister/housing was full (to the brim) with diesel fuel. I guess I'm not surprised... after all, the fuel must pass through the filter and fill the canister in order for it to have enough pressure to exit the canister.
How does one know whether or not any WATER is at the bottom of the canister? Does water simply sink to the bottom of the canister, while diesel fuel stays on top of the water? The entire contents looks like clear fluid, and smells like diesel. Should all the fluid be suctioned out of the canister as part of the cleaning/draining procedure? If so, should the canister be refilled with fuel in order to "prime" the system, or can I simply turn the ignition on to get the pump running and primed?
BTW - the filter looked very clean (white), so I simply replaced the cover of the canister and tightened down the 5 screws. Didn't suction anything out, nor replace the filter. Left the canister full of diesel (and maybe some water????)
My wife drive a 2011 Jetta TDI for over 180,000 miles before VW bought it back. The fuel filter - and oil filter - look about identical to the Jetta. I always clamped the hoses with vice grips before opening the fuel filter housing to prevent the hoses from draining while open. Never suctioned off any water because I never heard of it until this message board. Never had a problem. We had watched the VW tech use the clamps when he did it. Not sure if it’s needed, but I’ll do the same just in case. Thanks for the write-up!
