Control Arm Bushing DIY?
My wife's 2011 Cayenne S is exhibiting the signs of worn control arm bushings at 80k+ miles. I've searched the usual locations and haven't seen any DIY's for replacement. Is there any chance someone has a link to one? If not, I'll work on a write-up for the DIY section. Additionally, does anyone know what usually fails? Is it just the rear bushing, or do I need to be concerned about the ball joints and other bushings in the arm?
Thanks,
Jon
Thanks,
Jon
Thanks,
Jon
Thanks,
Jon
Just before I traded my CTT I began to notice a 'clunk' that seemed to come from the right front suspension area when turning the wheel sharply at low parking lot speeds, like when maneuvering into a parking spot. Would that be it?
Just out of curiosity, what are the symptoms when these need replacing?
I'm getting some knocking when going over uneven pavement. I'm going to put the Pig on a lift, and see if I can find any play in the bushings. From there, it looks like replacing the entire arm is the proper procedure, so I'll go that route, if it needs it.
Received 1,140 Likes
On the 955/957 - the hot setup for non-turbo cars was to put the turbo control arms on. The bushings were supposed to be stronger and longer lasting. Dunno if this is the case on 958's or not - but a quick perusal of an online parts catalog might be revealing.
My CTT had the same symptoms of clunking when driving over bumps. 80k miles. It was resolved by replacing the upper and lower control arms on both sides. Fortunately, it was covered under CPO warranty. However, I don't think the parts were all that expensive.
Check alldatadiy.com for the procedure.
Control arms on the Cayenne are huge revenue boosters for Porsche as they are designed to fail before 100k miles. One of the bushings Porsche uses is hollow (less durable) in the control arm and this is the one that always fails. My control arms only lasted 70k miles before they needed replacing, pretty sad for a $100k SUV. I decided not to go with OEM Porsche the second time around and went with an aftermarket control arm from a vendor who claims to overbuild them. Time will tell if they are "overbuilt", but figured I had nothing to lose.
jk930 (04-07-2022)
Mevotech Supreme. The Cayenne control arms I received have a bigger ball joint and and the structure of the arm has been increased (thicker). I was told the bushing is no longer hollow and now solid, which means it should last the life of the vehicle now. Just remember that Mevotech has two versions of control arms for the Cayenne, a cheap one, and a "supreme". You will want to get the "supreme" version if you care about longevity.
https://www.youtube.com/watch?v=zb-HhRJEhxI
https://www.youtube.com/watch?v=AbnkQDs7fMs
Eskimo1 (12-01-2021)
2006 911 Base MT Cab
2009 Cayenne Base
2019 Panamera Base
Fcpeuro.com sells both bushings and control arms (akatrailing arms).
I was going to do bushings, but there is no ball joint available for sale separately. Maybe I just didn't search hard enough. But I bought the Lemforder arms. They are OEM. Looking at the parts, looks like the Porsche part number and the P symbol stamps were shaved off to sell as an aftermarket part.
Plus FCUEURO warranties for life.
I also have the knocking sort of sound and in the past, on other cars I'd replace upper control arms which would fox this. Since I did up and lower arms on the Cayenne, I fixed 2 issues... tighter steering and steering wobble at 65mph. Still have some knocking type noise and I suspect it might be shocks. I'm not touching those ***** with a 6ft pole. They are 1500$ each I think since they are air shocks.
I was going to explore in changing other thinks like sway bushings, etc.. starting with cheapest.
Also, at some point I was curious as to the cost of ALL bushings and mount at the bottom, including engine, frame and trans mounts with all suspension parts. Comes out to around $2000 in parts from FCPEURO.
Good luck and if you find the ball joints for the lower arm, I'd be interested to see you replace it. The upper one is not replaceable at all.
