What did you do to your 958 today?
#916
@twodollardoug Interesting, Steinway's black, after aluminum, and "wood", (btw, which one ?)
I'm going to be be back on your root, with change #1 : wood !! (OEM was aluminum).
And, going for olive oil !
(Being lazy, the changes is done by a Porsche approved body shop.)
I noticed that you did not changed the gear trim that seems to be still aluminum, any reason (s) ?
Another question, where did you put your "past trims" on market ?
#917
I don't think the have a piano black shift **** in Espresso. But I would definitely be interested if you have a source.
#918
Liqui-moly oil change + Ravenol transfer case oil (always do them together). GTS now has 74k miles and also tackled the more laborious transmission fluid+filter change. Also removed the ATF hoses to purge additional fluid-definitely worth the extra trouble. Total amount replaced 10L. The fluid looked in amazingly good shape - I'm assuming it was still original. filter appeared very clean too.
#919
@twodollardoug if you don't mind having the metal plate on your phone / phone case, the rennline design is hands down the best phone holder on the market. I have them in 3 of my cars
r553 (12-29-2020)
The following 2 users liked this post by Radi:
deilenberger (12-29-2020),
jayi836 (12-29-2020)
#922
Any tips on doing the transmission oil change? I need to face up to that next year. What ATF did you use? I have an H9 AGM battery on order from Auto Zone.
#923
Received 1,160 Likes
I'd have to agree! Did your old wheel have the buttons/***** for controlling the PCM and dash display? I know on other models there is a separate steering column stalk that is used for those functions when the no-buttons sport wheel is used.
#924
MMMmmmm.... this thread isn't really for detailed tech discussions - I'd suggest you make a posting in the normal Cayenne forum for these sort of questions. And as far as the transmission you may want to go look at the Cayenne DIY subforum.
#926
t.ly/2LA9
1&tag=googhydr-20
t.ly/vpYI
r553 (12-30-2020)
