Sponsored By:
Sponsored By:
Apple Car Play for PCM 3.1
Old 02-17-2019, 09:20 PM
  #91
marinerbc
marinerbc's Avatar
Originally Posted by 604
Mariner, who installed your system in Vancouver???
i used trickfactory of Coquitlam, they had a second location at I think it was 930 Tupper Ave , Ask for Tim
will PM you his cell. Number
edit :’
could not send you a PM , check your inbox at 6speedonlime .
hooe that would help
Old 02-18-2019, 12:54 AM
  #92
604
7th Gear
604's Avatar
Thanks again!
Old 02-24-2019, 01:03 PM
  #93
BOLEN
BOLEN's Avatar
https://rennlist.com/forums/cayenne-...-pictures.html
Old 02-26-2019, 12:22 PM
  #94
sdunsworth
sdunsworth's Avatar
Is anyone aware of an installer in the Chicago area (North Shore or NW suburbs preferably)?
Old 03-04-2019, 02:12 PM
  #95
Flexxxx
Cruisin'
Flexxxx's Avatar
I am also looking for a Chicago area installer -- please let me know if you find one or if anyone has suggestions.
Old 03-06-2019, 05:25 PM
  #96
CTCayenneTurbo
Cruisin'
CTCayenneTurbo's Avatar
Can you be listening to Sirius/xm and still have Waze or Google maps doing nav functions ?
Old 03-07-2019, 07:09 AM
  #97
BOLEN
BOLEN's Avatar
This kit does not effect the XM capability
Old 03-07-2019, 10:42 AM
  #98
Dalema
Dalema's Avatar
true, but if you want to listen to XM don’t you need to select SAT? Versus the AUX you select for sound from the CarPlay (to be able to hear Waze)?
Old 03-16-2019, 01:54 AM
  #99
Galion
Galion's Avatar
Can someone confirm if I will loose my AUX BT with this Mod? if so, does this means I can only play my spotify music when plugged in to the supplied USB input? please advise
Old 03-16-2019, 10:58 AM
  #100
BOLEN
BOLEN's Avatar
you can play anything (any app ) on the iOS CarPlay side; also you WILL NOT lose your AUXBT input.
There is an option in the menu of the CarPlay system to switch between the Porsche PCM and the CarPlay system using the diamond key on the Porsche steering wheel.
I use it a lot but you can simply switch sources using the source button; while the CarPlay is active. Everything works fine.
afriedrich (03-16-2024)
Old 03-16-2019, 11:38 AM
  #101
Galion
Galion's Avatar
Thank you, that’s good news.
Old 06-14-2019, 03:31 PM
  #102
pitrow
pitrow's Avatar
Originally Posted by element
Just finished my install... I have the XM module, so needed 25mm risers and everything fit in there.. the risers are M2.5 and lots of kits available for $10 on amazon.
Overall the setup is pretty good, you do need to switch to AUX audio manually which is an extra click, but this is a hack. You cant have your radio playing something and carplay audio at the same time even though the screen is showing carplay.
phil.
Hi Phil.
Just ordered the wireless version off aliexpress to install in wife's Panamera. She needs XM so looking at the risers. Is there a specific size I need? Would a kit like this work?
Amazon Amazon
Really hoping this mod works well as I posted in a Cayenne thread around this topic, I'm looking at getting one and was only going to jump up to the '17 for the CarPlay integration and extra year of warranty, but would save $10K+ going with a similar mile '16.
Also, now that you've been living with yours for awhile, still pretty happy? Any issues to keep in mind?
Old 06-15-2019, 01:57 AM
  #103
Kayvan1347
Kayvan1347's Avatar
I was thinking to get that wireless version from AliExpress too. Please let us know the result.
Old 07-04-2019, 03:31 PM
  #104
Ziad Abou-Chalha
Cruisin'
Ziad Abou-Chalha's Avatar
HI all. I got the same unit and managed to install the board on top of the satellite radio by using longer screws that I luckily found in a local hardware shop with some plastic spacers to keep from sliding down. Now everything works fine except one thing, now I lost the AUX BT/ USB/ JUKEBOX option. The phone connects to the car and I can see my device and make calls but I can't see the AUX BT, USB or JUKEBOX option and media from my phone does not play through the PCM BT but it plays through the carplay BT. Any idea on how to fix this issue? Is it a connection problem or software? I am guessing maybe the HD is not connected. Any help is appreciated.
Old 07-06-2019, 08:46 AM
  #105
skinnytirez
skinnytirez's Avatar
Might seem trivial- but is your phone’s BT connection still paired to the PCM? Or only the CarPlay?
Please report back- I’m considering purchasing that same kit...
Quick Reply: Apple Car Play for PCM 3.1
