Sponsored By:
Sponsored By:
Anybody running a Malone tune on their diesel?
Old 01-14-2018, 03:35 PM
  #31
th3n1nj2
th3n1nj2's Avatar
So do these increase the fuel efficiency?
Old 01-14-2018, 10:05 PM
  #32
Eskimo1
Eskimo1's Avatar
Yep!
Old 01-15-2018, 08:06 AM
  #33
th3n1nj2
th3n1nj2's Avatar
Originally Posted by Eskimo1
Yep!
and also increase power and torque? Insane, this seems like a no brainer
Old 01-20-2018, 06:00 AM
  #34
Ddesimone17
Ddesimone17's Avatar
Been running the both Bluespark Pro , now upgraded to pro + boost for the past week . I honestly can say I can not tell the difference and mpg is the same.
i have been running them both on the same setting. So save your dough and just go with the pro.
Old 01-20-2018, 12:51 PM
  #35
docwyte
docwyte's Avatar
Interesting. Would think that increasing both boost and rail pressure would make a noticeable difference.
Old 01-20-2018, 01:44 PM
  #36
Ddesimone17
So,did i thus shelled out another $400, will play w the setting if not will return it
Old 01-20-2018, 04:21 PM
  #37
swmic
swmic's Avatar
Do the specs of the +boost box indicate a bump in performance compared to the pro box? Maybe safer?
Old 01-20-2018, 05:27 PM
  #38
docwyte
docwyte's Avatar
From what I understand, the +boost box add +2-3 lbs of boost depending on which map you're on. I know Greg was running map E8 on the + box...
Old 01-21-2018, 11:46 AM
  #39
Falcondrivr
Falcondrivr's Avatar
Subscribed.
Old 01-22-2018, 01:26 PM
  #40
Eskimo1
Eskimo1's Avatar
If you're adding more fuel and not more air, your EGT's are getting higher, faster. On a short burst, you might not feel much of a difference, but on a longer pull, it should take longer for EGT's to get to the defueling point (which seems to be 1450°F)..
Old 01-22-2018, 01:40 PM
  #41
User 52121
User 52121's Avatar
You've got that backwards.
More fuel = richer = lower EGT
Old 01-22-2018, 01:50 PM
  #42
Eskimo1
Eskimo1's Avatar
Not on a deezul, my friend.
cathalferris (04-18-2022)
Old 01-22-2018, 02:04 PM
  #43
User 52121
User 52121's Avatar
Hmmmm.
You are right. I stand corrected.
Old 01-22-2018, 02:14 PM
  #44
User 52121
User 52121's Avatar
Would be interesting to see some EGT data logs between the models, just to validate this theory.
Someone (forget who?) posted that they were able to log EGT with a generic bluetooth OBD2 scanner?
Old 01-22-2018, 02:34 PM
  #45
Eskimo1
Eskimo1's Avatar
That would be me.. The EGT's are definitely kept 'in check' by some DME programming. I guess it's just a matter of how fast you get to that limit! (Which leads me to think that removing all the DPF / EGR / etc. stuff will give you a definite performance boost due to it taking longer to hit a EGT limit)
Quick Reply: Anybody running a Malone tune on their diesel?
