Alarm stopped CHIRPING when armed!?!
2011 Cayenne Base
The audible Chirp when arming the alarm has stopped chirping for both keys #1 and#2. Lights still flash, alarm still functioning.
Mega search revealed no answers.
Worse yet, dealer can't tell me why, and cannot fix it.
Any thoughts?
Any thoughts?
Received 1,141 Likes
There is a setting in the vehicle settings that turns the chirp off. It's possible this somehow got changed. Another one of those you gotta dig down into the menus to find it - but it's there...
Do your interior lights kick back on when you lock it?
It could be indicating a central locking system fault. Sometimes when I unlock all the doors, or open the right rear, the lock doesn't actually lock on the right rear. It doesn't chirp, and the interior lights come back on. You can check this by locking it and trying to open the doors. If one opens, there's your problem. You'll want to check this with key in-hand, in case one does open and the alarm starts going off.
If this is your issue, I haven't gotten the door panel off to figure out the root cause, or to figure out how to fix it yet, but as an interim "fix" you can manually lock it with the rotating manual lock actuator in the door jamb, located above the child lock.
In my mega-search, it seems some Pcars have the ability to switch On/Off the alarm chirp under SETTINGS, but I can't find that option on my 2011 Cayenne Base.
Mine used to chirp, then quit suddenly.
And what's with the double "Honk" by Jayhawk's 2013 CD?
Is this unique to CD? weird.
projekt--thanks. I'll check that out
11s and 12s could have their beep disabled by the dealer (even early 13s I've heard). This is the first I've heard of a user selectable option.
Mid/Late 13s, however, did not allow the dealer to disable the beep. I cringe every time I lock my 13CD as that stupid double beep reminds me of that POS Golf I had ages ago...
I've heard that they brought the ability to disable the beeps back in late 14s and forward.
The sound from the loaner (brand new, 11 miles on the ODO) I had while my tank heater replaced was still rather whimpy, but it was quick, just one tone, and much quieter. I wouldn't have a problem living with that.
I have not checked since PIWIS III came out to see if they could kill that stupid horn for me now.
Registered User
mursy (08-06-2023)
As clarification: were you getting the "double beep" of the horn prior to doing this child lock/ manual lock deal? As described in my message above, I would much prefer the "chirp" over the "double beep" I get now on my 2013 CD.
