Cayenne Diesel purchase advice with check engine light
Hi,
I'm about to buy a CD from 2012 with around 115.000 miles on it.
The biggest concern after not owing a VAG like diesel car for ages is that, the owner, by itself, said that the car from time to time gets the engine light on because of bad diesel.
He said something about a sensor that is getting clogged but he doesn't know to much about cars. My assumption is that actually the diesel filter might be triggering this.
I have to say that I'm in Romania, where as part of EU, the diesel quality is very tough controlled but sometimes you can still get water in it from the station itself.
Could be actually an easy fix like a new diesel filter or might be something that from time to time do a bad readout like a sensor and this means that the particulate filter, catalyst and other might be in trouble too.
I would keep this car for 3-4 more years, around 10.000 miles per year and don't want to pay for nothing repairs, of course. The owner is the second owner, having the car for a year and less than 10.000 miles.
What are your advice on this?
Get the codes scanned. You don't want to assume. could be something as simple as the ad-blue heater - which is a larger job to fix, for a simple part. or the particulate filter. or the cats. or or or.... need the codes to find out.
Any ELM327 scanner will do the job? Asking this because last cars were BMW and Jaguar and neither of them do much or at all with the ELM. Is Porsche more on the generic scanners for most of the errors?
I was asking you also to try to seek the answer: the bad diesel with water in it might trigger the check engine light.
I'm also hoping if I do the trip (300 miles to the owner), to have the car with the errors not deleted. If there is something that appears from time to time and the owner has a friend with a scan tool, could also clear fault codes while waiting for me to arrive.
By the way, for sure is something that was discussed over and over but asking one more time: what to look after, other than the oil leakage under between engine and transmission? Any know repetitive fault of CD especially for high mileage ones?
Received 1,140 Likes
