Need to replace throttle body for a 2005 Cayenne base
Dealer wanted $550 for the part and $800 for labor.
I thought that was a little high.
Pelican had several throttle bodys listed ranging from ~$400 - ~$1200 and none of them matched the Cayenne.
So I came across parts geek which has a Bosch listed for a Cayenne base for like $180.
Any reason not to shop from there? If so what's the best alternative?
Lifetime Member
Lifetime Member
Throttle body is super easy... what makes you think yours is bad? Just be careful and deliberate with the plastic vacuum lines, etc., or else you will be ordering those too.
Does the throttle have a slight "stick" when you first press on it? If so, the problem is sticky buildup inside the diameter of the throttle body. When the butterfly closes, the edges "sticky" goo and don't want to release well. This is EMMINENTLY cleanable... I've done it on several vehicles with over 100,000 miles... takes minutes. You have to be able to reach the edges of the butterfly and clean those, and also clean the throttle body bore where the butterfly edges touch. Anything will work for cleaning... brake cleaner or isoproply alcohol both work great. Don't pour it in. Apply to a microfiber cleaning cloth that doesn't shed fibers and wipe surfaces clean. There's not much in the throttle body to fail... just a pivot, the butter fly valve and the body itself (casting or plastic), an external link that connects to the throttle (or an electrical wire connection to a servo motor that opens/closes the butterfly). If it has the electric servo... that's really about the only thing you might have trouble with causing the throttle to perhaps not open or close when you want it to (delays in responding). And they (throttle body assembly) really are easy to access and replace in most vehicles... $800 for labor is criminal for that small of an amount of work.
When she told me I opined that $800 sounded high and this confirms that suspicion, thanks
This sounds more like a guess at what was wrong other than the real solution. If the car completely stops, it could be caused by many things other than the throttle body... including the fuel pump stopping after it gets warm. When she said it "stops" does she mean the engine turned off, or that the engine kept idling, but lost speed down to a crawl? If the engine kept running but only at "idle" speed, that could indicate that the throttle butterfly was closing while she had the accelerator depressed... THAT sort of problem would point at the throttle body. If the engine completely turns off (loss of power brake boost and loss of power steering), that indicates you are losing spark or fuel completely and those wouldn't have anything to do with the throttle body. If communications aren't good with the ex, you may need to drive the vehicle yourself to determine the actual problem. I assume she was doing SOMETHING that would get the car running again after it "stopped"? And was not in need of a tow? So the car will still start and drive now? At least until the problem happens again?
I'll interview myself and drive if I have to in order to get more detail other than just "stopping"
The pictures of the throttle body in this article don't match up with what I'm seeing under my hood.
I suspect this article was written for a V8 and mine's a (2005) V6 (base).
Anyone know where the throttle body is on a V6? I searched online but only saw pictures of the part itself.
The location shouldn't be much different. The Throttle Body allows air into the intake manifold on top of the engine. Throttle bodies are either on top of the intake manifold or close to the intake manifold with some sort of tube or plenum carrying the air to the top of the intake manifold. It sounds like the V-8s have electronic (servo motor) control of the butterfly so if that's the case for the V-6 also, there won't be a throttle "cable"... you'll have throttle electrical wires instead. The throttle body may be covered up by a big plastic trim panel on top of the engine that has to be removed to access the throttle body.
chitin (01-09-2021)
