Need to replace throttle body for a 2005 Cayenne base
Does throttle body replacement require any reprogramming?
Even a throttle position reset or idle position reset?
I don't have any diagnostic tools or programmers.
Originally Posted by Mister Quickie
Nope, just plug n play
You simply turn the ignition to the on position, with the engine off, and wait 30-60 seconds. Make sure you don’t touch the gas pedal while you wait. After about 1 minute, you’ll hear the throttle plate moving for a few seconds. Once it’s stopped, turn the ignition off. That’s it, the throttle position has been reset. Make sure you’re somewhere quiet so you can hear when it’s done, or open the hood and stand in front of the car and listen.
