957 open headlights or how to clean them inside?
Received 1,140 Likes
I suspect if you Google around - you'll probably find a place that does vehicle wraps (and commercial wraps - advertising) in your area. The one near me had a computer generated pattern for the Cayenne headlight that fit it exactly. He cut out a pair in about 30 seconds from some thin normal clear-bra. It took him about a minute per side to fit them perfectly - no bubbles, no marks - they're invisible to the eye, but if you gently touch the edge of the headlight you can just feel the outer margin of the film. Cost was around $40 or something close to that. Then he liked the Porsche enough that he did some trimming on the body clear-bra that wasn't perfectly installed.. for free. Did a very nice job.
If you zoom in on these pictures, you can see the fog on both headlights (more visible in the first pic than the 2nd one)
Here are pictures of the Driver's side headlight after the alcohol swish and thoroughly drying
If anyone needs a new headlight housing (minus the bulb and ballast, which I moved over to the new housings), this one is for sale for $650 + shipping and PP fees.
Here's the process I used - get some 91% rubbing alcohol and a hypodermic needle. Remove the headlight from the car and pop off the back caps, then introduce enough of the alcohol in a direction that keeps it away from the electrical components. You need enough where when holding the light lens down you'll be able to swish it around on the inside of the lens. Once you've done that for a while, make sure you haven't picked up any debris from inside the light assembly that is sitting on the lens and then turn it upside (lens at the top now), shake the alcohol out, and let it dry that way for a day or so. If you let it dry lens down any remaining alcohol will run back onto the lens and make a stain. Once it's dry inside that inside haze will be gone.
The V8 Porschephile
For the cloudy haze on the interior of the lenses on my 957, I used the magnet method and it worked perfectly. Home-Depot sells 1/2" wide ceramic magnets that will fit through the aperture of the high beam halogen bulb (see photo).
1) Remove headlight assembly using provided tool in tool kit
2) Remove headlight harness connector by pushing down on lever and wiggling the connector outwards. Be patient as this may take some time to remove.
3) Place headlight assembly on a bench (on a towel) and remove service cover for high beam bulb. Turn bulb holder counterclockwise and remove bulb assembly from aperture; taking care not to touch bulb with your fingers.
4) Using cotton material (old t-shirt works best), wrap the attracting side of both magnets and tie a small bundle in back of each magnet using a twist tie wire. Trim excess wire so that it will not scratch the lense when dropping it inside. The magnet used on the exterior is wrapped so as to avoid scratching the exterior of the lense while swiping.
5) Soak one of the magnets in 70% Isopropyl alcohol and invert the lense downwards while dropping the soaked magnet into the assembly. Using the other wrapped magnet, place it on the exterior portion of the lense so that it attracts the soaked magnet. Once they've mated, swipe in a side-to-side and up-down motion to remove the haze. You will notice a black residue that will accumulate onto the cotton material.
6) Remove magnet from assembly and replace cotton wrap with a new one. Clean again. Keep repeating this process until the cotton material no longer shows dirt & grime.
The V8 Porschephile
I simply inverted the lens and the magnet finds its way back through the high beam bulb aperture. Remember to keep changing the cloth repeatedly and reapplying the alcohol, otherwise you will get hazy swipe marks that will only be visible in direct sunlight.
I attempted this last night with glass towel, hanger wire and some isopropyl alcohol. It turned out great! I may go in with a fresh rag at a later date to clean them up a bit more, but they are fine for now. I am highly impressed with how easy it was to remove the headlights! Thanks OP for the great write up!
JD
Before
After
JD
Before
After
Following up - the lights cleaned up nicely, however I am having some issues with the driver's side headlight now.
I'm now receiving the resident "check dipped beam" warning and the Xenon bulb is not turning on, the cornering lamps are no longer functioning however the high beam works. Off to check and clean the connectors.
Hi, is there any possibility to open the headlights on the 957 TTS or to remove the lamps so I can get access to the inside of the glass to clean the headlights from the inside. Both of my headlights are covered by a dirt/dust on the inside. From the outside it looks like a milky layer. I went to the Porsche dealer and we removed both headlights and tried to clean the glass from the inside. The biggest problem is to get access to clean the glass from the inside. Does anyone know how to open the headlights or how to remove the inside lens so it will be possible to get access to the inside?
Big thx,
Alex
Big thx,
Alex
