So what can collect in a Turbo grill?
Old 05-28-2017, 05:38 PM
John Veninger
John Veninger's Avatar
Default So what can collect in a Turbo grill?
Need to remove the front bumper cover to replace the right parking light/turn signal due to a small crack and moisture.
Couldn't believe the amount of leaves and road grime collected in there including a small bird!
Poor bird.....Maybe I'll gain a few HP back due to the inter-cooler working a bit better.
Upclipped the cooler to get behind and removed all the crud
Old 05-28-2017, 07:27 PM
BamaScoot
BamaScoot's Avatar
Dayum! I need to remove my 08 turbo front bumper for the exact same problem (moisture in passenger side blinker).
Old 05-28-2017, 10:16 PM
John Veninger
For some reason the passenger side one gets cracked. I remember when I was shopping for mine and saw several with passenger side lights "wet".
Old 05-29-2017, 09:22 AM
Petza914
Petza914's Avatar
Received 6,154 Likes on 3,923 Posts
Wow, that's why I fabricated a screen kit for the Misha bumper that's going on my widebody build. It has even larger front openings and I wanted to protect the upgraded FVD Intercoolers.
I have the OEM Driver's side intercooler from an '09 Turbo S for sale in the Marketplace if anyone needs a fresher one with fewer bent fins or less crud stuck in it.
Old 05-29-2017, 02:58 PM
Andy E.
The V8 Porschephile
Andy E.'s Avatar
John, it's pretty nasty in there. The dead bird sorta finishes everything off with a bang.
The GTS has the same grill openings (less the intercoolers) and I've never had to get in there to pick anything off the rad.
A word of advice. If you're removing your front bumper cover, make sure your horns function well, since they have a habit of ingesting water; given their location and orientation.
Old 05-29-2017, 03:11 PM
John Veninger
Good point about the horns. Mine are working well. Im sure they will stop next week now that I took the cover off!
Old 05-29-2017, 11:40 PM
TheUnscented
TheUnscented's Avatar
Can you post a link to removing a 958 Turbo bumper?
Mine came with some after market grills I'd like to remove when I change my oil this week.
Old 05-30-2017, 10:45 AM
white rock
white rock's Avatar
I had a bird once
Old 05-30-2017, 11:05 AM
JAGMAN1
JAGMAN1's Avatar
The inter cooler grills remove without tools. I make vacuuming out the crap that collects a regular part of my upkeep. 2-4 cleaning per year on average. Only takes 10 seconds to pop out the grills.
The center radiator grill is a bit more challenging. I'd is taped in and doesn't come out easily.
Quick Reply: So what can collect in a Turbo grill?
