New Owner of a 2006 Cayenne Turbo S
Purchased last night, I'll post pics once it's washed.
It is missing the spare tire. Can anyone tell me if the Turbo non-S tire will fit? Thanks in advance.
My 06 CTTS came from the factory with a Bose subwoofer and a can of Porsche tire sealant in the compact spare tire holder instead of a spare.
If you do find a compact spare, it will have to be at least 19" wheel size to fit over the front calipers so its very likely that a standard Turbo spare will not fit.
My 06 CTTS also had the subwoofer and no spare. There is a spare that can be used. I have the part number somewhere but cannot find it. I removed the subwoofer and use the space for tools etc.
Ah Ha. Found it. https://rennlist.com/forums/porsche-...subwoofer.html
Yep, you're covered. Just make sure your Cayenne still has a functioning air compressor hose. It's usually stored under the driver side back seat. I also carry a tire plug kit. I'm going to be traveling in some pretty remote areas later this year (some gravel roads but mostly pavement) so I will probably go ahead and get the compact spare if it fits over my subwoofer. Not losing the sub
