100,000K service: What Else?
My Very reasonable Indy is doing my 06 S 100k
Tune up.
What else should he do for preventative maintenance while he had the car?
Thank you
Tune up.
Thank you
Gearbox (ATF), diffs and transfer box oil change. You'll have to replace the gearbox oil filter and gasket if you get the gear oil changed.
Originally Posted by alpesh26
Gear, diffs and transfer box oil change. You'll have to replace the gear oil filter and gasket if you get the gear oil changed.
I would also suggest doing the coolant, power steering and brake fluid and a oil change (if needed) as well while he's in there. Might as well have all fresh fluids so you won't have to worry about them for a while.
Plugs and coils?
My Indy said do plugs, wait on coils!?
There is a TSB on coils?
Oil change
Plugs
Cabin and air filters is all.
Oil change
Plugs
Brakes flushed (again) oil change(Valvoline stripped out the rear drain plug what do I do?) Plugs,all air filters and not coils.
Thanks, just ordered a set. Car runs great. Bought the Bosch wiper lades. Seem to be better than most.
