How I got the siezed cardan shaft off the Cryenne :)
Old 05-21-2016, 05:40 PM
cfiiman
cfiiman's Avatar
Default How I got the siezed cardan shaft off the Cryenne :)
Finally got around to switching out my cardan shaft today. On the V6 the job is cake, literally would take me 30 minutes start to finish if I had to do it again, but getting the shaft to release from the rear end was a nightmare. I searched all the forums and found people that said you tap this, pry that and while that may work with some it definitely wouldn't have worked with mine. Then I saw the bearing puller which was a good idea but I didn't feel like going to the store so what to do. Well I put the front of the shaft back on the tranny and tightened a couple bolts then jumped in the car and threw it in gear and brake torqued her a couple times in both D and R, "pop" she came right off I know this probably isn't the most recommended thing to do but for us lazy folks it worked perfect lol.
Old 05-23-2016, 11:27 AM
69gaugeman
69gaugeman's Avatar
Another one is the seized rim on the hub. Loosen all the bolts about a mm. Do a figure eight in the parking lot (or less) and Ta da! rim is off the hub!
Old 05-24-2016, 04:32 PM
Nacho82
Nacho82's Avatar
I used the same method as you to remove the frozen on shaft when I changed mine out. I believe it was a suggestion I saw posted over at renntech. Just like you, I had already unbolted the front, so I had to put it back together before getting the rear off.
Quick Reply: How I got the siezed cardan shaft off the Cryenne :)
