Changing Cayenne Wheels
As I'm finding, your suspension will also thank you. It'll ride a lot better.
Yes, this is what I'm thinking. Acceleration, fuel economy, wet roadholding, and ride (no "porpoising"/underdamped condition) in realistic road surfaces hopefully can be improved.
Interesting note, the 20" options that are OEM for the 957 use a 275/40 R20 tyre. The OEM 958 RS Spyder wheels size is 275/45 R20, something to be aware of if buying a set that comes with ready rubber on them.
I've had the GTS back for a few days with the RS wheels.
Observations:
- No more metallic, high pitch road noise on Seattle's worn freeways
- No more loud thumps when going over potholes. This may confirm my suspicion that my 22" tires' sidewalls were insufficient
- Less steering wheel vibration
- I can now detect difference in various suspension settings among comfort, normal and sport. On the low ride setting, comfort and normal were not discernible to me with the 22"s; it always felt like it was on sport mode but with too much underdamping
- Acceleration/deceleration responsiveness improved
- Have not tested ultimate grip but grip is much better on imperfect and wet roads. Pushing it on dry street roads, speeds were certainly high enough for me.
Though perhaps some of my issues can be attributed to the tires, it's hard to argue over handling improvements due to lighter rotational weight.
Here's a quick photo or two.
Observations:
I'm a little late to the thread but here is a 958 w Sport Technos. I went from Turbo II 19"s to these (9x20) w all season SottoZero tires. Really like the look, easy to clean, and very strong. I weighed the original wheel/tire which had Mich Lattitudes and the new set and the new are 2.8 pounds heavier (66 vs 68.8) each. I can't tell much difference in ride quality or road noise. I do not have AS.
Received 1,160 Likes
Observations:
Observations:
I'm sure the sport Latitudes are the best for handling, but switching between the two on my '06 in the same size tire (19" rims) the DWS had it hands down for comfort, noise and ride quality. Perhaps a bit less ultimate dry grip, but a LOT more grip in any sort of weather (wet, snow) and the vastly improved wear factor is just icing on the cake.
If you had Michelin Latitudes and went to the DWS's - IMHO the biggest difference is the tire. The taller sidewall will absorb bumps better - but the slap that you get when going over something like a poorly paved road-cut (which are endemic in NJ.. they simply slop so asphalt in them and go home) was all tire.
Another thing: while the DWS' taller sidewall may indeed be the factor in absorbing bumps better, the change to 20" is what enabled to have taller sidewalls for the same overall tire diameter.
Btw, I think you're right on the DWS' ride quality and grip in more adverse weather conditions.
The differences you feel are from both the wheels and tires. Chinese wheels, especially 22's will almost always vibrate at hwy speeds. If you still have any steering wheel vibration, usually apparent at 80-85 mph, have them re-balanced. I am with you on 20's being the sweet spot.
I've had 17s and 18s in my past Cayennes. Though tire (model/design/construction) is a variable, I'm beginning to think that 20s are the sweet spot for these cars and 22s are too much for the Cayenne's suspension design/setup as well as visual proportions. The latter is more subjective of course.
What does the wheel and tire combo weigh? 70+ pounds?
I run OEM 21 turbo wheels on my '13S in the summer and 18s with all weather tires in the winter. Withe the air suspension the 21s are fantastic. Smooth in comfort mode and stiff for handleing purposes in sport mode
I think the 18s are too small and would prefer 19s for winter wheels. Here in the North east we get pothole craters this time of year. I have never had an issue with the 18 in terms of flats or bent rims but they look a little small in the space.
