soft close liftgate help request
soft close liftgate help request (solved)
Been having trouble with my soft-close and need a reference for what "normal" is from someone else. Mine is a 2004 CTT.
The powered latch at the bottom stays in the middle of its range of travel at rest, and when the liftgate latch microswitch closes (like when closing the liftgate), the motor turns and draws the bottom latch in, but then back out all the way and back to where it originally was.
I can see this by manually closing the top latch when the liftgate is open. Would someone mind trying this to see how their bottom latch moves? Thanks.
It is. I thought that is what mine did originally as well. I think I somehow moved the "home" position of the soft-close motor when I closed the liftgate too hard. I will probably have to replace the soft-close motor; opening it up looks like a big pain.
I would test the microswitch first. You could have damaged the alingment or it could be dirty. I just did a full hatch removal and adjustment.
Does the motor itself (on the lower latch, just above the rear bumper) have a switch as well?
I tested the micro switch in the liftgate itself. About midway through its travel, it will make the lights on the bottom of the hatch turn off, and when depressed fully it will activate the soft close motor.
Problem solved.
My external button for opening the liftgate wasn't activating the microswitch. There's a little detent thing that controls the motion of the bar inside the button, and it was out of position and keeping the microswitch from being activated.
After I unplugged the switch, put the detent back in place, and put it back together, everything went back to working. The soft close motor returned to its "normal" ways of staying out until the latch connected, and then drawing in. I didn't have to use a durametric or anything.
As a side note, the rear hatch works WAY better with all the heavy trim removed. It lifts so much faster and higher now!
Problem solved.
my lower latch wont move whatsoever even wjen I turn the upper latch twice by hand. Something is missing here electronically or signally.
