Coolant Leak from trans housing
Going to revive a dead thread but I just found coolant leaking from my transmission bellhousing today and after pulling the intake off this evening it clearly came from a broken vent line and the other vent line attachment is also leaking.
Orantes nailed it. Led me straight to my problem. Thank you
It was initially a small crack in the fitting near the left head, but when i touched it it, it cracked wide open.
If you folks have the intake manifold off, i would replace this h piece - its probably brittle and near failure.
