Feel the hate. Bosch quietcast pads are braking my heart.
I will not skimp to save a few bucks on brakes or other safety related items.
http://www.944turbo.com/cayenne-brake-kit.html
Lifetime Member
Lifetime Member
Another vote for stock pads. They are simply the best in all conditions.
I am using EBC yellows right now and cant wait to wear them out to go back to stock.
Porsche is very good at figuring out what works. Especially braking systems.
I think Pagid is the oem supplier to the CTT for brake pads. Pairing them with Zimmerman or Brembo rotors and fresh brake fluid. 👍🏻 I also changed the flexlines due to cracking with ECS braided. Very high quality product for a very reasonable price.
P.s to the above poster. I have used EBC reds. Hated them. They glazed all the rotors and caused them to pulsate. The only upside was the brake dust or lack of.
A few weeks ago I changed brake pads and did a flush. I replaced OEM pads with OEM pads. Flushed Porsche OEM DOT 4 with Porsche OEM DOT 4 fluid. Excellent stopping and a nice firm brake pedal. I was quite happy with OEM performance before so I stayed with it. My only real heavy braking is when I tow my trailer and car (~ 6500 lbs total tow weight). I have trailer brakes too, but never had any issues with the CD stopping under that heavy tow load. If you search my user name you can find a short comment to a brake thread where I gave some pointers about changing the front pads of the 92A (958) model Cayenne. The rears are standard and simple.
re: caliper bolts - Porsche says replace them at each brake pad change due to stress (brakes build a lot of heat and over time the metal fatigues easier). They are cheap and easy to replace since you have to remove them anyway to change the pads.
Yeah that makes sense and it's a no brainier to change a cheap part given the safety implications. Because I have o my had this crappy ECS kit on for a few thousand miles I just thought I'd ask.
The symptoms you described, did that happened right away or over time? I really appreciate your feedback as glazed rotors definitely reduce stopping efficiency. I hope I don't have to replace these pads.
What weather conditions do you typically see with the brakes. No doubt - there are brakes out there that will stop better and have better feel than OEM. Where OEM shines is covering the entire range of usual driving conditions. EBC, Hawk - on previous cars, it was cold and wet where they often gave it up compared to OEM. Warm and dry - many pads will stop better and dust less. It's really dependent on what weather you see and what you want out of your pads.
Been very happy with the performance of the Centric Posi-Quiet ceramics. I first did the fronts first to see how they felt compared to the previous pads which were the Centric Posi-Quiet extended wear.
The difference was night and day. The ceramics are a far better pad than the extended wear. Compared to the Pagid pads, the ceramics don't have the initial grabiness and after bed-in, the performance has been consistent and linear with good bit once warm. I suspect either the semi-metallic or ceramics are both equally good (for me). I put the ceramics on the rears shortly after and now am happy with the braking performance. It's not expensive either at about $150 for front and rears.
Another vote for OE Porsche pads. Best all around performance. Good bite when cold, good when hot. Maybe not the best track pad, but since 99.9% of driving is not on the track a decent trade off.
I've had EBC's on other cars, and felt that the initial bite when cold was bad. The other consideration is rotor wear; with Porsche pads I can get 2-3 pad sets per rotor change. If that ratio changes for the worse, then my costs go way up.
Yeah I'm going with OE. I need good initial bite when cold because I live in a small town and there are frequent short trips. It was mentioned in a PM that I should probably get my rotors resurfaced. They only have about 2k miles of use and id rather avoid the cost. Is that a fools errand?
