Stupid Question - Air Intake Distributor
Stupid Question here:
How do I get the lower hose off the air intake distributor. I broke my distributor trying to get it off.
Thank you!
Thank you!
I'm not sure what the Air Intake Distributor is. If you mean the plastic Y that connects to the throttle body,
http://www.pelicanparts.com/techarti...eplacement.htm
figure 4: ...to disconnect the vacuum fitting below (green arrow). Squeeze the two tabs in and pull the fitting off.
<img src="http://www.pelicanparts.com/techarticles/Porsche-Cayenne/24-ENGINE-Throttle_Body_Cleaning_and_Replacement/images_small/pic04.JPG">
