Anyone else have a Steering column replacement
Hi,
15 mins after parking the other day, i get back in to pull out and car would not crank. Wouldnt even turn on beyond the dash and radio.
After towing it to the dealer, found out 'steering lock failure' was the culprit.
The repair requires the whole steering column to be replaced, including the kessr Computer.
Was quoted 4800 parts and labor.
Ive seen a few other people that had it done for around 3k. Anyone have an invoice or input on the price.
Mpfaff (07-14-2019)
http://www.renntech.org/forums/topic...g-column-work/
Cliff notes: you can replace just the lock mechanism without removing the entire steering column, but you still must purchase a brand new column.
Keep us updated on the fix.
Anyone have a part number for the column. Or link to buy it.
Pretty sure it's 95534700720. Looks like the going rate is roughly $1400-1600
http://www.gaudinporscheparts.com/oe...FQeKaQodDqoL0A
It ended up being the steering lock mechanism. Failed, required replacement of steering column and computer for about $4500 after discounts.
Hurt the wallet a bit but havent had any problems since.
Quoted $9,350 for this replacement -- O_o
My '08 Cayenne Turbo immobilized itself. Flatbedded it to Porsche of Warrington, PA. After a week, they just quoted me $9,352 to replace the steering column and Kessy control unit.
I'm speechless. I scarcely even know how to respond to that. Any helpful suggestions?
Here are three plans for getting it fixed:
Plan A
1. Go get a bottle of your favorite **** lube
2. Let the dealer bend you over for almost 10 thousand dollars
Plan B
0. Fill a grocery bag full of dog and cat feces.
1. Go back to the dealer and ask to see every single person involved in that estimate.
2. Get said people in a circle.
3. Swing the sh!tbag around like a medieval mace and try to hit all of the human sh1tbags in the face at least once before it explodes on one of them.
4. Call a flatbed to take your car back to your house.
5. Hire one of the avid members on here who knows whats up and fly them out to your house with a case of cold beer waiting (I am sure someone will take you up on this for less than $9k...)
6. Ask them to to replace the relays or hall sensors that have failed in the board (~ $25)
7. Drive back to the dealership to tell them that they are crooks. If you feel so inclined bring some horse **** this time.
Plan C
1. Do some searching on here
2. Buy some tools and learn how to work on your car
3. Take the relatively cheap and easy way out using the speedo solutions replacement module
Plan B sounds like the most fun to me, but it is your call. Remember, we don't call them stealerships for nothing!
Plan A
Plan B
Plan C
Decisions decisions
Plan A is a bad plan. But Plans B and C both have their own appeal. I'm pretty comfortable doing some work, and will probably try the speedosolutions option first.
Nine thousand effing dollars. It's so absurd I'm still laughing about it.
I'll come back and update. (But don't let that stop any of the rest of you from posting plans D and E.)
Called a dealer that sells discount Porsche parts the other day in Las Vegas. I happen to be from Las Vegas so I still have that area code on my cell number. I was calling to inquire about stock of trailer hitch bolts that were priced @ ~$4.50 each on their website before I placed the order. When I gave him the part # to check stock and told him I needed 8 he responded with "we will have to order those and it will be $163 for 8". I responded with " I was just calling to check stock before I order online where they are listed on your site for ~$4.50 ea." There was a most awkward extended moment of silence at that point before I said " I will go ahead and place the order online, thank you".
They must have their discount parts website blocked to Las Vegas IP adresses and when he saw my area code figured that is where I was. LOL - frickin' cracked me up and the bolts came super fast like he had them next day aired to him from the wharehouse before they shipped to me. But I will never forget the "Cost of being on the cutting edge VS. Bleeding edge and do I know the difference" speech I got from one of the board sponsors here. I wonder if that speech is still given as part of that individual's sales strategy?
*grin*
My steering lock was faulty, I was able to fix it for about $8 and the cost of a Durametric diagnostic cable ($280)
In my case it was the relays that send power to the steering lock motor. The lock relay was bad, and so the steering lock wouldn't lock. The cars alarm system would read this and brick the car, so you couldn't drive it and have it inadvertently lock the column while driving.
If your column is in the lock position, this is a little more difficult, but if it is in the unlocked position, then this is pretty easy to fix.
Here's the short version:
Read more here.https://rennlist.com/forums/cayenne-...l#post14029763
- Under the dash there is a shiny metal box attached to the steering column with tamper proof bolts, you have to Dremel a slot in these bolts to remove the lock.
- Once you remove the protective cover you can loosen the Torx bolt that holds the box to the column and remove it. If the steering is unlocked! Then go to step 5.
- If the steering is locked, then you need to do step 1 then dremel the crimps on the electronics box to remove the cover plate.
- Then you pull out the circuit board. And you can apply voltage to the motor to unlock the column. Then you can remove the torx bolt in step 2. Go to step 6.
- Dremel off the crimps to remove the cover plate over the electronics, pull out the circuit board.
- Replace the 2 relays on the circuit board.
- Grease the steering lock mechanism! (very important since the old lithium grease they used is hard and the reason why the lock relay fails after passing too much current to move the lock motor.
- Reassemble the lock to the steering column.
