Cayenne 8-speed trans--Aisin or ZF?
My general and absolutely unofficial info is that the 8-speed in the current Cayenne is one of the ZF models introduced a few (?) years ago. But I read something--where I know not--to the effect that's it's a Japanese Aisin.
Does anyone KNOW the answer to that? And if so can you point me at its ratios?
Believe me, I'm not arguing with you, but...
...I found the source of the Aisin idea...
http://www.myturbodiesel.com/wiki/20...-buying-guide/
"The 8 speed (sic) tiptronic (sic) automatic is made in Japan by Aisin. The gear ratios are listed below (7th and 8th are double overdrive) (*).
gear 1 2 3 4 5 6 7 8 final
ratio 4.97 2.84 1.864 1.437 1.21 1 .825 .686 3.273"
* That's certainly misstated. Seventh gear is overdrive; 8th is the double-overdrive.
I still wonder which it is. hahnmgh63, what's the source of your info?
Has anyone personally seen, say, a transmission case with a brandname on it?
Yes, TYVM Hahn. Here's more info on this Q7/Toureg/Cayenne Diesel transmission.
http://ae-plus.com/vehicle-development/audi-q7/page:1
Here's a spreadsheet of ratios and percentage changes.
RPM Rise, ...............................RPM Drop,
Downshifting...Gear.....Ratio.......Upshifting
75.0%...............1......4.970..........-----
52.4%...............2......2.840........42.9%
29.7%...............3......1.864........34.4%
18.8%...............4......1.437........22.9%
21.0%...............5......1.210........15.8%
21.2%...............6......1.000........17.4%
20.3%...............7......0.825........17.5%
------.................8......0.686........16.8%
