955 Minor Issues
955 Minor Issues
My console cigarette lighter was converted to be a fulltime dual USB charger. Somehow, my ham-fisted girlfriend "broke" the retractable feature of the lighter socket. When the ashtray is opened, the lighter socket no longer pops-up, like the 944 headlights do. Also, how do I remove the entire ashtray main drawer assembly? I can only remove the inner liner tray.....which I also "broke" into 3 pieces. Below are the 3 main issues:
1) The ashtray liner has a tiny spring, for the swinging flap. However, I have not a clue how this spring is oriented(center of photo):
2) Ashtray is fully extended out - but the lighter socket/USB interface no longer raises UP like it used to. The USB charger weighs LESS than the OEM cigarette lighter:
3) Left turn signal shows a "Check Direction Indicators" error message, with accompanying "!" dash warning. The blinkers form inside the car appears to be 2x faster.....but when I go outside to check front and rear - both bulbs appear to be not burned-out and blinking at "normal" interval. Can this be bulb contacts? Where and how do I clean them?
Thanks In Advance!!!!
Old thread, but rather than create a new one, will ask on this one.
Mine just started doing this too. I had mine opened for about 1 year, with a dashcam adapter in the lighter socket and it now does the same thing. Won't come up.
Inside the ashtray assembly is a delicate plastic prop that levers the lighter receptacle up, whenever the ashtray drawer opens.
I found boneyard replacements a much cheaper option...
