Cayenne S 2006 Gearbox Issues
Hi Guys... I´m new on Rennlist and hope you can give me a good advice on this...Here I come with some questions .. I have a Cayenne S 2006 with 82K. I start having issues with the gearbox ..when I push Kick down and the gearbox goes down from 5 gear to 4 gear,...makes and hard conecction ( no smooth at all)..I ask here about any failure..but there is no failure code. Gearbox is Aisin,..hope that the ATF oil level might be a little low and maybe I can get rid of this situation and use the car more agressive for driving.
Do you have some advise of what might be these situation and how to fix it?
Thanks Guys from Chile
Paul
Paul
The Transgo may be an aftermarket alternative but I would first review the TSB Porsche has out on this. May need a whole valve body or maybe just fresh ATF & Filter.
here I found some interesting thing ......
VW 09D, Aisin TR60SN
Automatic Transmission Parts
"Transmission repair manual 09D, TR60SN
The Japanese company AISIN Co., LTD is the manufacturer and developer of the Rear Wheel Drive TR60SN transmission, which is a 6 speed, fully automatic and electronic controlled transmission. Volkswagen engineers were also involved, in conjunction with Aisin, in the development process for their vehicles and Volkswagen gave it the "09D" designation. The TR60SN, 09D transmission is used in a wide variety of applications and engine sizes. As a result, the number of friction plates, and planetary gears (3 or 4 pinion), will vary depending on torque load requirements of the specific vehicle. The TR60SN transmission uses a gear ratio sensitive system, requiring the correct transmission interchange. The TR60-SN is currently used in the Porsche Cayenne, Volkswagen Touareg, and Audi Q7 vehicles. The 09D transmission uses a Lepelletier arrangement, using a simple planetary coupled with a Ravigneaux type, dual planetary. This is the same type of gear set that was used in the FMX. This arrangement makes six forward speeds and reverse possible, with only five clutch packs and one freewheel. This manual contains the procedures necessary to diagnose, rebuild and/or repair the TR60SN "09D" transmission and is intended for automotive technicians that are familiar with the operation of automatic transmissions. "
T59165 Shift Kit, 09D (not 09G!)
TransGo # SK O9D
Shift Kit Fits: 6spd 2004-07 Touareg, 2003-06 Porsche Cayenne
Corrects/Reduces/Prevents Rough shifts, flares during up-shifts & kickdown. Rough coast downshifts no pressure rise, TCC slip/shudder.
http://www.makcotransmissionparts.com/VW09DTR60SN.html
TransGo # SK O9D
TransGo # SK O9D
TransGo # SK O9D
My wife's 06 CS seems fine on highway driving in 5th/6th but when stop and go major abrupt kickdown from 4-3-2 and clunky upshifts from 2-3-4. Car when cold no real symptoms til it's warmed up. Thoughts and thanks. I think it needs a new transmission. Mike
